Openhab rule engine error on startup
  • Platform information:
    • Hardware: _i3-4010U CPU @ 1.70GHz/8GiB/SSD 240GB
    • OS: Fedora Linux 4.20.6-100.fc28.x86_64
    • Java Runtime Environment: openjdk version “1.8.0_191”
    • openHAB version:openHAB 2.4.0 Release Build
  • Issue of the topic:
    In my openhab on restart error appears. One rule is not initialized. When I edit and savae it in Paper UI it starts working.
    /var/lib/openhab2/jsondb/automation_rules.json
“bb96754d-561f-4bed-8285-34d35c2e0dc4”: {
“class”: “org.eclipse.smarthome.automation.dto.RuleDTO”,
“value”: {
“triggers”: [
“id”: “1”,
“label”: “an item state changes”,
“description”: “This triggers the rule if an item state has changed.”,
“configuration”: {
“itemName”: “RFBridge_RFSwitchSecond”,
“previousState”: 0.0
“type”: “core.ItemStateChangeTrigger”
“conditions”: [],
“actions”: [
“inputs”: {},
“id”: “2”,
“label”: “send a command”,
“description”: “Sends a command to a specified item.”,
“configuration”: {
“itemName”: “Furtka_FurtkaSwitch”,
“command”: “ON”
“type”: “core.ItemCommandAction”
“inputs”: {},
“id”: “3”,
“label”: “play a sound”,
“description”: “Plays a sound file.”,
“configuration”: {
“sink”: “webaudio”,
“sound”: “doorbell.mp3”
“type”: “media.PlayAction”
“configuration”: {},
“configDescriptions”: [],
“uid”: “bb96754d-561f-4bed-8285-34d35c2e0dc4”,
“name”: “Furtka_2”,
“tags”: [],
“visibility”: “VISIBLE”,
“description”: “Furtka if second switch”
“b903d3e1-1440-4e5d-9f5d-0d3ddaf43644”: {
“value”: {
“triggers”: [
“id”: “4”,
“label”: “an item receives a command”,
“description”: “This triggers the rule if an item receives a command.”,
“configuration”: {
“type”: “core.ItemCommandTrigger”
“conditions”: [],
“actions”: [
“inputs”: {},
“id”: “5”,
“configuration”: {
“sink”: “webaudio”,
“sound”: “barking.mp3”
“uid”: “b903d3e1-1440-4e5d-9f5d-0d3ddaf43644”,
“name”: “Say “Furtka””,
“tags”: [],
“f77f03a5-6e97-42d8-be53-249e1961df48”: {
“value”: {
“triggers”: [
“id”: “1”,
“configuration”: {
“itemName”: “RFBridge_RFSwitchFirst”
“conditions”: [],
“actions”: [
“inputs”: {},
“id”: “2”,
“configuration”: {
“command”: “ON”
“inputs”: {},
“id”: “3”,
“configuration”: {
“sink”: “webaudio”,
“uid”: “f77f03a5-6e97-42d8-be53-249e1961df48”,
“name”: “Furtka_1”,
“tags”: [],
“description”: “Furtka if first switch”
  • If logs where generated please post these here using code fences:
```csv
2019-08-26 22:46:56.325 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.88.10' with clientid paho609404108368627 and file store '/var/lib/openhab2/mqtt/192.168.88.10'
2019-08-26 22:46:56.616 [ERROR] [utomation.module.script.defaultscope] - bundle org.eclipse.smarthome.automation.module.script.defaultscope:0.10.0.oh240 (214)[org.eclipse.smarthome.automation.module.script.defaultscope.internal.DefaultScriptScopeProvider(234)] : The addThingActions method ha
s thrown an exception
        at org.eclipse.smarthome.automation.module.script.defaultscope.internal.DefaultScriptScopeProvider.addThingActions(DefaultScriptScopeProvider.java:125) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.inject.methods.BindMethod.invoke(BindMethod.java:42) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1809) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.DependencyManager.bindDependency(DependencyManager.java:1637) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.DependencyManager.bind(DependencyManager.java:1625) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:301) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) [39:org.apache.felix.scr:2.1.2]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
        at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
        at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
Welcome to the OpenHAB community!
Sometimes on startup, things can get loaded out of order, it is a know issue but usually somewhat harmless. If everything is working, don’t worry about it. If something isn’t working, try restarting OpenHAB
Thank you for answer, but your answer is quite strange. This one rule isnt working. I dont want to restart openhab until it starts working.I need a solution
then just touch the rule file, how’s that sound? Just resave it, doing so will reload the rule and if it is a valid rule, it should run
ok?
