OpenHAB sends float instead of int to MQTT-Broker (1.000000)
Since the new update, OpenHAB is sending my int-values as float-values to the mqtt-broker.
It worked before but now it’s suddenly broken.
Items
Number example001 " " {channel="mqtt:topic:broker001:smarthome:example001"}
Switch example002 " " {channel="mqtt:topic:broker002:smarthome:example002"}
Things
Type number : example001 [stateTopic="smarthome/example001/status", commandTopic="smarthome/example001/status"]
Type switch : example002 [stateTopic="smarthome/example002/status", commandTopic="smarthome/example002/status", on="1", off="0"]
Rules
rule "dev001"
    Item dev001 received update
      example001.sendCommand(1)
      example002.sendCommand(ON)
Result in MQTT
smarthome/example001/status=1.000000
smarthome/example002/status=1
What changed or what did I do wrong?
From what old version to what new version?
I don’t know which old version but I is probably from the end of 2019.
New version: 2.5.3
Related
Thank you, rossko57!
I marked this reply as the “solution” because in my case (int) it is a bit different to the existing topic.
Transferred to my issue
formatBeforePublish="%.0f"
or
formatBeforePublish="%d"
Things
Type number : example001 [stateTopic="smarthome/example001/status", commandTopic="smarthome/example001/status", formatBeforePublish="%.0f"]
