openHAB serial dependency : how does it work?
I think users would be happy to be able to use that as an additional option based on
Can I use “/dev/serial/by-id”?
. :slight_smile:
You can probably already use them because the RXTX serial transport will add any configured device path to the list of ports in gnu.io.rxtx.SerialPorts .
But I read there is a bug which crashes the JVM which currently prevents using long device names. :confused:
See also:
So I think after upgrading nrjavaserial to a version that has the fix the only missing part is adding these identifiers to the discovered port identifier list so they can be more easily configured?
