Good idea. There are android TV boxes that could work well as a controller. It could be a good intro for people to try out openhab…
Hi Marcel,
Are you running both android and linux on the stick? I tried the link provided below but there isn’t anything there. My plan is to run Linux inside android os as virtual machine based on the following: https://sourceforge.net/projects/linuxonandroid/files/?source=navbar.
https://sourceforge.net/p/linuxonandroid/wiki/Complete%20Manual/
https://www.youtube.com/watch?v=8Fy6Y5ZfAu4&feature=youtu.be
Using virtual machine I should be able to run openhab on android because this thing is not exactly as virtual machine, it uses same Linux kernel. I have my own hardware that is a android STB wtih built in zwave.
Hi @ishorter
I’m running the linux on the TV stick, but not parallel.
So it can either boot in Android or in linux. Have not tried to run a VM in Android.
Curious how running the VM works out, esp memory wise.
Let us know your findings
