I followed the instructions as written on the page:
Everything went well but when I try to start the server it returns an error 1067 can’t start service.
When I googled this error I found several solutions mostly related to a bad configuration file which is not the case for my setup.
After a while I tried to run the server with my own credentials and it worked. So it looks like the “localsystem” account doesn’t have the rights to start the service.
I did use an elevated command prompt to install the service, so that is not the cause of the issue.
Any suggestions?
This provides a windows service that manages openhab without any changes to openhab configuration files. I’ve been running it for months and it works great…
thank you for your suggestion. I have openHAB running as a service, but only with admin credentials instead of localsystem. Of course I can use your tool to maybe bypass this issue, but it doesn’t solve the real problem. I am just wondering if this is an openHAB bug or something related to Windows 10 default security settings.
No idea actually - I’d look at the karaf logs and the event viewer to see what it’s saying when you try to use localsystem. I’m sure it’s something security related however…
I googled all the items in the forum about these kind of issues again and I found a hint that it can be caused by the JAVA_HOME environment setting. It should be a system setting and not a user setting. Apparently I overlooked this in the installation instructions.
After correcting this setting it all worked.
