i tried to get mqtt also working. Switching Channels works fine, but Openhab doesn’t recognise the status yet. So when i switch in shelly cloud, openhab doesn’t get the new state.
michael, you made my day…uhhh, how complicate this shelly staff with mqtt, since pro versions…? i’m woundering how to find out the right code and syntax. can you explain, how you found the right path? would be helpfuel to me for future issues…thanks!
andy
I’ve just checked again and realised that the other state read outs, like posted as a sample earlier in this this threat do not work either, such as voltage for example. Did anybody test anything else then the switches?
Hi @htttito .
Just came accros your post.
Are you getting status updates on your channel if the switch gets initiated by any other source than openHAB (e.g. Shelly WebGUI or touchscreen on the device)?
Your stateTopics looks off to me, should rather be something like this to work properly - correct? :
