Hello together,
i was 3 weeks in vacation and last sunday my openhab suddenly shutdowns… no idea why…
After restart of the pi still not accesibly through webinterface…
Via terminal/putty i was able to access the openhabian…but still no access to the frontend…I only was able to enter the log via openhabian:9001 but there were just time changes…
2018-03-29 17:29:21.724 [vent.ItemStateChangedEvent] - Sun_Elevation changed from 23.83 to 23.08
2018-03-29 17:29:53.254 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-03-29T17:28:53.213+0200 to 2018-03-29T17:29:53.235+0200
2018-03-29 17:29:53.274 [vent.ItemStateChangedEvent] - Date changed from 2018-03-29T17:28:53.213+0200 to 2018-03-29T17:29:53.235+0200
2018-03-29 17:30:53.274 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-03-29T17:29:53.235+0200 to 2018-03-29T17:30:53.261+0200
2018-03-29 17:30:53.278 [vent.ItemStateChangedEvent] - Date changed from 2018-03-29T17:29:53.235+0200 to 2018-03-29T17:30:53.261+0200
2018-03-29 17:31:53.296 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-03-29T17:30:53.261+0200 to 2018-03-29T17:31:53.269+0200
2018-03-29 17:31:53.302 [vent.ItemStateChangedEvent] - Date changed from 2018-03-29T17:30:53.261+0200 to 2018-03-29T17:31:53.269+0200
After updates through console…and restart in terminal no changes…
Only as i installed the “Log Viewer” as an optional component…everything seems working again…see log…some links and everything…
2018-03-29 17:32:53.312 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-03-29T17:31:53.269+0200 to 2018-03-29T17:32:53.289+0200
2018-03-29 17:32:53.318 [vent.ItemStateChangedEvent] - Date changed from 2018-03-29T17:31:53.269+0200 to 2018-03-29T17:32:53.289+0200
2018-03-29 17:33:53.321 [vent.ItemStateChangedEvent] - Current_DateTime changed from 2018-03-29T17:32:53.289+0200 to 2018-03-29T17:33:53.303+0200
2018-03-29 17:33:53.327 [vent.ItemStateChangedEvent] - Date changed from 2018-03-29T17:32:53.289+0200 to 2018-03-29T17:33:53.303+0200
2018-03-30 14:12:39.413 [INFO ] [egram.internal.TelegramActionService] - Bot Carsten loaded from config file
2018-03-30 14:12:39.439 [INFO ] [egram.internal.TelegramActionService] - Bot Hannah loaded from config file
2018-03-30 14:12:41.802 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-03-30 14:12:42.770 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to de_DE, Location set to null, Time zone set to Europe/Berlin
2018-03-30 14:12:45.337 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.177.77.70:8080
2018-03-30 14:12:45.342 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.177.77.70:8443
2018-03-30 14:12:46.730 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 9d923b72-bf98-4dcf-8c73-313903ee1a5a, base URL = http://localhost:8080)
2018-03-30 14:13:01.701 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netzwerk_status.items'
2018-03-30 14:13:02.003 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'homematic_heizung.items'
2018-03-30 14:13:02.309 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'harmony.items'
2018-03-30 14:13:02.410 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'groups.items'
2018-03-30 14:13:02.579 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kodi.items'
2018-03-30 14:13:02.653 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dummy.items'
2018-03-30 14:13:02.700 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fritzbox.items'
2018-03-30 14:13:02.772 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'wetter.items'
2018-03-30 14:13:02.833 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2018-03-30 14:13:02.906 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'homematic.items'
2018-03-30 14:13:02.962 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lights_hue.items'
2018-03-30 14:13:03.060 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'xiaomi_vacuum.items'
2018-03-30 14:13:03.165 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netatmo.items'
2018-03-30 14:13:03.212 [WARN ] [ore.common.registry.AbstractRegistry] - org.eclipse.smarthome.core.items.GroupItem with key 'gBatterie' already exists! Failed to add a second with the same UID!
2018-03-30 14:13:03.313 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.items'
2018-03-30 14:13:03.344 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'miflora.items'
2018-03-30 14:13:03.399 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'icloud.items'
2018-03-30 14:13:04.133 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2018-03-30 14:13:07.175 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-03-30 14:13:11.145 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.rules'
2018-03-30 14:13:16.052 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'simulation.rules'
2018-03-30 14:13:16.181 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.rules'
2018-03-30 14:13:16.679 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'homematic.rules'
2018-03-30 14:13:19.152 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netzwerk_status.rules'
2018-03-30 14:13:25.245 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'harmony.rules'
2018-03-30 14:13:25.384 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'astro.rules' is either empty or cannot be parsed correctly!
2018-03-30 14:13:26.199 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'wohnung.sitemap'
2018-03-30 14:13:26.825 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'netzwerk_status.things'
2018-03-30 14:13:27.016 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2018-03-30 14:13:27.233 [.ItemChannelLinkAddedEvent] - Link 'hmip_etrv2_wnz_signal_strength-homematic:homematic:HmIP-eTRV-2:48e27df4:000A1709A65D17:0#SIGNAL_STRENGTH' has been added.
2018-03-30 14:13:27.237 [.ItemChannelLinkAddedEvent] - Link 'iPad_Carsten_Location-icloud:device:a6be3d1b:d69ce582:location' has been added.
2018-03-30 14:13:27.242 [.ItemChannelLinkAddedEvent] - Link 'Netatmo_Bedroom_HomeCoach_Location-netatmo:NHC:aa47e291:70ee5025e326:Location' has been added.
2018-03-30 14:13:27.246 [.ItemChannelLinkAddedEvent] - Link 'fritzdect200_office_energy-avmfritz:FRITZ_DECT_200:192_177_77_1:087610341517:energy' has been added.
2018-03-30 14:13:27.251 [.ItemChannelLinkAddedEvent] - Link 'applewatch3_Carsten_LocationLastUpdate-icloud:device:a6be3d1b:ba97040:locationLastUpdate' has been added.
2018-03-30 14:13:27.261 [.ItemChannelLinkAddedEvent] - Link 'Netatmo_Bedroom_HomeCoach_Unit-netatmo:NHC:aa47e291:70ee5025e326:Unit' has been added.
2018-03-30 14:13:27.272 [.ItemChannelLinkAddedEvent] - Link 'hmip_etrv2_bad_duration_value-homematic:HmIP-eTRV-2:48e27df4:000A1709A649AF:1#DURATION_VALUE' has been added.
2018-03-30 14:13:27.276 [.ItemChannelLinkAddedEvent] - Link 'hmip_swsd_wnz_signal_strength-homematic:HmIP-SWSD:48e27df4:000A58A989FF7A:0#SIGNAL_STRENGTH' has been added.
2018-03-30 14:13:27.279 [.ItemChannelLinkAddedEvent] - Link 'hmip_etrv2_wnz_active_profile-homematic:HmIP-eTRV-2:48e27df4:000A1709A65D17:1#ACTIVE_PROFILE' has been added.
2018-03-30 14:13:27.281 [.ItemChannelLinkAddedEvent] - Link 'hmip_etrv2_wnz_low_bat-homematic:HmIP-eTRV-2:48e27df4:000A1709A65D17:0#LOW_BAT' has been added.
2018-03-30 14:13:27.284 [.ItemChannelLinkAddedEvent] - Link 'Netatmo_Bedroom_HomeCoach_DateMinTemp-netatmo:NHC:aa47e291:70ee5025e326:DateMinTemp' has been added.
2018-03-30 14:13:27.287 [.ItemChannelLinkAddedEvent] - Link 'ping_fritzbox_cmhw_1-network:pingdevice:ping_fritzbox_cmhw_1:online' has been added.
2018-03-30 14:13:27.290 [.ItemChannelLinkAddedEvent] - Link 'hmip_etrv2_wnz_actual_temperature-homematic:HmIP-eTRV-2:48e27df4:000A1709A65D17:1#ACTUAL_TEMPERATURE' has been added.
2018-03-30 14:13:27.293 [.ItemChannelLinkAddedEvent] - Link 'myKodi_stop-kodi:kodi:3fc27565:stop' has been added.
2018-03-30 14:13:27.295 [.ItemChannelLinkAddedEvent] - Link 'ping_google_home-network:pingdevice:ping_googlehome:online' has been added.
2018-03-30 14:13:27.298 [.ItemChannelLinkAddedEvent] - Link 'statusClean-miio:vacuum:03D88748:status#in_cleaning' has been added.
2018-03-30 14:13:27.301 [.ItemChannelLinkAddedEvent] - Link 'wohn_licht_hue_tvstripe_dimmer-hue:0210:001788412fcd:5:color' has been added.
2018-03-30 14:13:27.307 [.ItemChannelLinkAddedEvent] - Link 'myKodi_mute-kodi:kodi:3fc27565:mute' has been added.
2018-03-30 14:13:27.309 [.ItemChannelLinkAddedEvent] - Link 'hmip_etrv2_wnz_boost_time-homematic:HmIP-eTRV-2:48e27df4:000A1709A65D17:1#BOOST_TIME' has been added.
2018-03-30 14:13:27.311 [.ItemChannelLinkAddedEvent] - Link 'iPhone_Hannah_BatteryStatus-icloud:device:a6be3d1b:29b7beac:batteryStatus' has been added.
2018-03-30 14:13:27.317 [.ItemChannelLinkAddedEvent] - Link 'Netatmo_Bedroom_HomeCoach_PressureUnit-netatmo:NHC:aa47e291:70ee5025e326:PressureUnit' has been added.
2018-03-30 14:13:27.318 [.ItemChannelLinkAddedEvent] - Link 'iPhone_Carsten_BatteryLevel-icloud:device:a6be3d1b:a0f4b9f2:batteryLevel' has been added.
Any idea??
BR
Multisaft7
