I am trying to bridge between OH and Smartthings using this binding - https://github.com/BobRak/OpenHAB-Smartthings. I wasn’t sure whether to post here or on the github repo.
I have connected the two and am able to switch the bulb on and off but I am unable to set the brightness of a bulb. In my setup I have the following:
smartthings.things
Thing switch Light_4Switch [ smartthingsName=“Light_4” ]
Thing switchLevel Light_4Level [ smartthingsName=“Light_4” ]
smartthings.items
Switch iSmartthings_Hallway1Switch “Hallway 1 light” { channel=“smartthings:switch:MyHome:Light_4Dimmer:switch” }
Dimmer iSmartthings_Hallway1Dimmer “Hallway 1 dimmer” { channel=“smartthings:switch:MyHome:Light_4Dimmer:level” }
When I try to set the brightness, in events.log I see:
Item ‘iSmartthings_Hallway1Dimmer’ received command 20
2020-10-08 06:40:02.564 [ome.event.ItemCommandEvent] - Item ‘iSmartthings_Hallway2Dimmer’ received command 20
2020-10-08 06:40:02.569 [ome.event.ItemCommandEvent] - Item ‘iSmartthings_Hallway1Switch’ received command ON
2020-10-08 06:40:02.619 [nt.ItemStatePredictedEvent] - iSmartthings_Hallway1Dimmer predicted to become NULL
2020-10-08 06:40:02.641 [nt.ItemStatePredictedEvent] - iSmartthings_Hallway1Switch predicted to become ON
And the light comes on but the brightness does not change. I have tried all sorts of combinations, including enabling the Switch and SwitchLevel items in the ST app, and referencing the switch and switchLevel object in my .things and .items files but no success.
Any help greatly appreciated.
