I am hoping someone could help me or point me in the right direction. I have installed Openhab and I have created a deamon. I can start it by typing sudo /etc/init.t/openhab start. But it won’t run on startup.
You will need to observe your system a bit. Reboot and check your logfiles (/var/log/boot etc) on hints. Did you try to disable and enable the service? This “System start/stop links for /etc/init.d/openhab already exist” could also mean, that your system is trying to start openhab too early. Try sudo update-rc.d openhab defaults 80 10 for a delayed start.
But I am not guessing here. You are dealing with a Linux technicality you should be able to solve if you dig into it a little.
But again, I am not sure if the effort is worth the time, to be quite honest here. “my processor” as in old processor - as in old pc? Maybe you should think about switching to a cheap and enegry efficient Raspberry Pi? jm2c
