I exactly installed Openhab according apt-get … on a Raspi PI" with Jessie. I started OH according wiki
with sudo systemctl start openhab.
Any ideas?
Many thx in advance
Peter
Any ideas?
Many thx in advance
Peter
You can try enabling it with this command:
sudo systemctl enable openhab.service
Hi works,
but changing user & group to to root dosn’t solve the problem with
Jan 05 16:07:38 raspberrypi openhab.sh[1088]: 2016-01-05 16:07:38.036 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyAMA0
Jan 05 16:07:38 raspberrypi openhab.sh[1088]: 2016-01-05 16:07:38.126 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyAMA0 does not exist
Jan 05 16:07:42 raspberrypi openhab.sh[1088]: 2016-01-05 16:07:42.943 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been shut down
Double check the following:
Make sure openhab is indeed in the dialout group
getent group dialout
It should read something like dialout:x:20:openhab
Make sure /dev/ttyAMA0 exists and has usable permissions
ls -l /dev/ttyAMA0
It should read something like crw-rw---- 1 root dialout 188, 0 Jan 5 10:58 /dev/ttyUSB0
Make sure your z-wave controller is actually at /dev/ttyAMA0 and not /dev/ttyAMA1 or /dev/ttyUSB0 or the like. You can check this by seeing which devices disappear when you unplug and which reappear when you replug the device back in. NOTE: when you replug it back in it may one up the number so it would start as /dev/ttyUSB0, unplug and this device disappears, then plug it back in and it will show up as /dev/ttyUSB1.
Make sure openHAB is running as root
With the changes to that config file openHAB should be running as root:root. Check this by running:
ps-elf | grep openhab
You should see a line like the following:
4 S openhab 12426 1 0 80 0 - 1119 wait Jan04 ? 00:00:00 /bin/sh /usr/share/openhab/bin/openhab.sh -o
The third column is the user who owns the process. In your case it should be “root” now.
first many thx for your support, I checked all, all result are as expected, but error message stil there, Yesterday I ordered a zwave Gen5 Stick. In think this is a special issue with the razzbery board …Hope this works …
Peter
one question: after booting the raspberry I get with: sudo /etc/init.d/openhab status
pi@raspberrypi:~ $ sudo /etc/init.d/openhab status
● openhab.service - Starts and stops the openHAB Home Automation Bus
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled)
Active: active (running) since Mi 2016-01-06 13:04:16 CET; 1min 7s ago
Docs: http://www.openhab.org
Process: 447 ExecStartPre=/usr/share/openhab/bin/setpermissions.sh (code=exited, status=0/SUCCESS)
Main PID: 688 (openhab.sh)
CGroup: /system.slice/openhab.service
├─688 /bin/sh /usr/share/openhab/bin/openhab.sh -o
└─710 /usr/bin/java -Dlogback.configurationFile=/etc/openhab/logback.xml -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true…
Jan 06 13:04:16 raspberrypi setpermissions.sh[447]: setting permissions and owner openhab:openhab for /usr/share/openhab/webapps/static
Jan 06 13:04:16 raspberrypi setpermissions.sh[447]: setting permissions and owner openhab:openhab for /etc/openhab/jetty/etc/keystore
Jan 06 13:04:16 raspberrypi setpermissions.sh[447]: setting permissions and owner openhab:openhab for /etc/openhab/configurations/users.cfg
Jan 06 13:04:16 raspberrypi systemd[1]: Started Starts and stops the openHAB Home Automation Bus.
Jan 06 13:04:54 raspberrypi openhab.sh[688]: 2016-01-06 13:04:54.220 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been star…v1.7.1).
Jan 06 13:04:59 raspberrypi openhab.sh[688]: 2016-01-06 13:04:59.397 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
Jan 06 13:04:59 raspberrypi openhab.sh[688]: 2016-01-06 13:04:59.588 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initializat…mpleted.
Jan 06 13:05:09 raspberrypi openhab.sh[688]: 2016-01-06 13:05:09.316 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
Jan 06 13:05:14 raspberrypi openhab.sh[688]: 2016-01-06 13:05:14.860 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
Jan 06 13:05:22 raspberrypi openhab.sh[688]: 2016-01-06 13:05:22.198 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /s…s/habmin
Hint: Some lines were ellipsized, use -l to show in full.
pi@raspberrypi:~ $ ls -l /dev/ttyAMA0
crw–w---- 1 root tty 204, 64 Jan 6 13:04 /dev/ttyAMA0
it seems to me Opnehab is started:
After
pi@raspberrypi:~ $ sudo systemctl start openhab
I get this result:
Active: active (running) since Mi 2016-01-06 13:04:16 CET; 3min 24s ago
└─710 /usr/bin/java -Dlogback.configurationFile=/etc/openhab/logback.xml -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djet…
Jan 06 13:05:22 raspberrypi openhab.sh[688]: 2016-01-06 13:05:22.198 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.760 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyAMA0
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.763 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 2
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.767 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.861 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.865 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. S…is false.
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.868 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyAMA0
Jan 06 13:05:27 raspberrypi openhab.sh[688]: 2016-01-06 13:05:27.962 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyAMA0 does not exist
Jan 06 13:05:32 raspberrypi openhab.sh[688]: 2016-01-06 13:05:32.772 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been shut down
Jan 06 13:07:36 raspberrypi systemd[1]: Started Starts and stops the openHAB Home Automation Bus.
Peter
Yes, its running. The only problem I see is the z-wave error but you are already working to deal with that.
