When I define a rule, I need to set it an hour earlier, since OpenHAB log lines seem to be an hour different (in my case) earlier. My timezone is Europe/Brussels. Where should I set this correctly? Is this an issue with summer/winter time or timezone?
I had similar problem. OpenHAB or Joda time should use your System time zone and will Fall back to UTC.
In my case System time zone was ok and openhab was using it when I started it manually from the Console. But when openhab gets started from rc.init it was incorrect. I guess System time zone initializes later then…
