- Platform information:
- Hardware: Raspberry 4
- OS: Raspbian
- Java Runtime Environment: the one the came with openhabian
- openHAB version: 2.5
- Issue of the topic:
Today Openhab became unresponsive on port 8080 after over one year of flawless operation.
I can not open port 8080 in browser.
Grafana (installed at port 3000) works as ususal.
Rebooted pi several times
openhab seems to be active (openhab-cli status)
at the logs there are errors:
2020-06-18 20:50:57.582 [WARN ] [raf.features.internal.osgi.Activator] - Error starting activator
java.io.IOException: Unexpected end of input at 1:1
at org.apache.karaf.util.json.JsonReader.error(JsonReader.java:337) ~[bundleFile:?]
at org.apache.karaf.util.json.JsonReader.expected(JsonReader.java:331) ~[bundleFile:?]
at org.apache.karaf.util.json.JsonReader.readValue(JsonReader.java:93) ~[bundleFile:?]
at org.apache.karaf.util.json.JsonReader.parse(JsonReader.java:58) ~[bundleFile:?]
at org.apache.karaf.util.json.JsonReader.read(JsonReader.java:52) ~[bundleFile:?]
at org.apache.karaf.features.internal.region.DigraphHelper.readDigraph(DigraphHelper.java:93) ~[bundleFile:?]
at org.apache.karaf.features.internal.region.DigraphHelper.loadDigraph(DigraphHelper.java:72) ~[bundleFile:?]
at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:146) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:312) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Any idea what i can do?
Console seems not to be available. Trying openhab-cli console shows
Failed to get session
