Hello Community,
I got some serious problems with my openhab 2.
I am running a openhabianpi and have the following bindings in use:
Hue binding
Xiaomi mi home
Denon
Mqtt 1 & 2
Plus some others like led wifi, nothing major I think.
The longest time I had no persistence set up and did that recently with mapdb. Unfortunately I think it never really worked like I expected. The system was after a reboot not ready like it was before the reboot. A little hard to explain. Rules took a while to work and bindings needed uninstall and reinstall⦠so I think thats not how it was suppose to be.
Anyway, since yesterday my openhab is totally messed up after a restart. My hue binding is asking for a userid. And when i see in the logs that i should press the bridge button, nothing happens either. All the sudden the deinstalled denonmarantz binding is back eventhough im using the denon 1 binding. My xiaomi sensors are not working anymore⦠my mqtt is working BUT the devices i have on zigbee2mqtt are not showing in the logs eventhough i have them in my item files like before (and all the necessary transformations are there too). I checked in the console also if zigbee2mqtt is maybe just not running, but that is not the case. It is in fact up amd running just not showing in openhab. So some off my rules are not getting the proper triggers and are not working because of that.
All together, a big mess. I am wondering what I can do? I uninstalled and reinstaled hue multiple times, deleted the thing⦠nothing.
How can I get my way thru that mess? How should I start? Tips? Is the persistence maybe a factor here?
Thanks in advance!!
