i am trying to migrate from fhem to openhab and want to give it a shot.
For now i am happy with the ground setup and it seams to work fine, but i have one problem, where i haven’t found a solution and it’s quite major.
For simplicity:
I have a LD382A which i added with the Wifiled Addon and i have setup an Homegear with HM-CFG-LAN and peered a switch (HM-PB-6-WM55).
So far all seams to work fine, i can for example switch my light on and off via the Control Panel in the Paper UI. And in the Eventlog i see the buttons triggered of my switch.
Now i linked them and it does not work, because the light is enabled and instantly disabled again.
Here is what i mean what shows up in the log with a single press of a button on my switch:
2018-10-28 02:19:38.332 [vent.ChannelTriggeredEvent] - homematic:HG-HM-PB-6-WM55:63b0d0a3:NEQ0434267:1#PRESS triggered SHORT
2018-10-28 02:19:38.341 [vent.ItemStateChangedEvent] - Bettlampe changed from OFF to ON
2018-10-28 02:19:40.332 [vent.ItemStateChangedEvent] - Bettlampe changed from ON to OFF
I only used Paper UI for adding the things, create a power item for the light and linked the switch to it.
Is there something obvious i don’t see or could done wrong?
Thank you for any help, i appreciate it
regards Michael
