martmiwp
(Michael )
March 16, 2018, 5:08pm
1
Hi!
I just updated my 2.3 snapshot.
Now I see the error:
2018-03-16 18:01:54.183 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-http1, openhab-binding-exec, openhab-misc-market, openhab-binding-irtrans1, openhab-misc-openhabcloud, openhab-persistence-influxdb, openhab-binding-modbus1, openhab-ui-habpanel, openhab-transformation-regex, openhab-misc-ruleengine, openhab-transformation-jsonpath, openhab-persistence-rrd4j, openhab-ui-basic, openhab-ui-classic, openhab-action-mail, openhab-binding-tradfri, openhab-binding-astro, openhab-ui-habmin, openhab-binding-squeezebox, openhab-binding-homematic, openhab-transformation-exec, openhab-binding-knx, openhab-ui-paper': Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-ui-basic; type=karaf.feature; version="[2.3.0.SNAPSHOT,2.3.0.SNAPSHOT]"; filter:="(&(osgi.identity=openhab-ui-basic)(type=karaf.feature)(version>=2.3.0.SNAPSHOT)(version<=2.3.0.SNAPSHOT))" [caused by: Unable to resolve openhab-ui-basic/2.3.0.SNAPSHOT: missing requirement [openhab-ui-basic/2.3.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.ui.basicui; type=osgi.fragment; version="[2.3.0.201803161151,2.3.0.201803161151]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.ui.basicui/2.3.0.201803161151: missing requirement [org.openhab.ui.basicui/2.3.0.201803161151] osgi.wiring.host; osgi.wiring.host=org.eclipse.smarthome.ui.basic; bundle-version=0; filter:="(&(osgi.wiring.host=org.eclipse.smarthome.ui.basic)(bundle-version>=0.0.0))" [caused by: Unable to resolve org.eclipse.smarthome.ui.basic/0.10.0.201803161254: missing requirement [org.eclipse.smarthome.ui.basic/0.10.0.201803161254] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.core.types.util)"]]]
Or the important part (I guess) out of this long message:
Any thoughts or hints what is going wrong?
Michael
martmiwp
(Michael )
March 16, 2018, 5:55pm
2
… after editing
/var/lib/openhab2/etc/org.openhab.addons.cfg
and removal of the basic-ui
the system comes back to live…
??? Any suggestions???
Thomas_G
(Thomas G.)
March 16, 2018, 9:16pm
3
Same problem here!
Removed the basic-ui, as you said, so I can login to paper-ui at least.
But: my homematic-base thing is stuck in “initializing” state!
Panic
job
(Joachim Boeddeker)
March 17, 2018, 12:55am
4
I had that problem as well. Only copying an older 2.3 snapshot installation from a clone gave me a working system again. Using an older deb didn’t help as it downloaded the all new add-ons. (Basic-ui is my main interface so i couldn’t simply remove. I tried it, but i couldn’t install afterwards)
Maybe this was due to being in the middle of a big upgrade, but i will not test that right now, because my system is working again.
https://community.openhab.org/t/unit-support-knx-2-karaf-4-1-5-upgrade-and-more/41904
If you don’t have a running system you could/should try again.
phil2fer
(Phil2fer)
March 17, 2018, 6:52am
5
Try to upgrade to the lastest snapshot Build #1231 , it solve the problem for me
phil2fer:
Build #1231
what is Build #1231 ?
is 2.3.0.001-SNAPSHOT not last release?
job
(Joachim Boeddeker)
March 21, 2018, 9:28pm
9
The build# is shown in the bottom when you go to openHAB in your browser.
thank you Joachim, I have not reached that step yet because I have the issue as this post
Openhab-ui-basic fails to start
I found out my version is openHAB 2.3.0 Build #1203 .
where can I download Build #1231 ?
thanks
job
(Joachim Boeddeker)
March 21, 2018, 10:17pm
12
What os are you using? If you are debian based, apt-get update and apt-get upgrade should help
Hello Joachim
I am using synology dsm 6.0
now I install old version 2.2 and works
I just installed openHAB 2.5.0 Build #1526 and am getting the same type of error. Any ideas?
2019-02-20 15:29:16.484 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-ui-basic, openhab-ui-paper'
wborn
(Wouter Born)
February 20, 2019, 10:09pm
17
It’s due to the UI addons having been moved to the openhab-webui repo. I’ve created a PR which should fix this:
i have the same issue, is there any quick fix i can do ?
wborn
(Wouter Born)
February 21, 2019, 7:51am
19
The quick fixes I can think of:
restore backup (if you’ve made one)
downgrade to working snapshot/milestone
add UI addon JARs to /addons dir
i had to rollback to a lower build number, which fixed the issue, hope it is fixed soon thanks
