Hello community. There is a following task: We have smart house installation with flooding sensors. Where flood sensor send us a signal about flooding, in upper left or right corner of each UI page must occur sign to notify user about flooding. How can we do that ?
Signal about floding (discrete) we get from external PLC via Modbus protocol.
You can’t do that on a sitemap based UI, but you can have a line that is only visible when an Item is in a certain state (e.g. floodAlarm==ON) and of course you can have red text and icons etc.
Must this line be manually inserted at each UI page (as we do that with other lines with switches, temperatures, sliders etc.) ?
If you are using a sitemap (you haven’t said) the only way to add content to a sitemap is to edit the sitemap file.
If you are using Group on a sitemap to automatically display a “sub-page” there is no way to add anything to the sub-page.
If you are using Text { … } or Group { … } to display a sub-page under your control then you would have to add content to each of the { … } block(s) of the sitemap for the content to be visible on the sub-page(s) as well.
