Hello team
here is a short request
I’m a beginner and I have a little problem.
Hardware or software used.
Raspberry 400
connected LAN
Connected WiFi
OpenHabian ( last download v3.3.0 )
Samba access is ok (data can be transferred from Win 10)
Fritz box ( download via OpenHab )
FritzDect 200
iPhone X
Last IOS
OpenHab
HomeKit integration (download via OpenHab)
Sonos (download via OpenHab)
so now to the problem:
the openhab works so far, i can switch the fritz dect 200 socket and the other desired functions.
If I now change the HomeKit integration configuration (port changed to 9154 / pin reset / with and without network ip) on the
add apple handy in home this will be set up.
you can find it under
setting of home
control centers & bridges
( XXXXX ) OpenHab
A message appears at the top:
This device is not certified for Homekit.
therefore, not all functions may be available.
in the home menu i find all my homepod and my tv device.
these are also accessible via Siri.
However, I can do what I want, the devices set via openhab are not
available or not accessible.
I’m assuming that I still have to set something that I haven’t found or read.
I hope you can give me a tip
Kind regards
Balu the bear
