Based on my rather limited understanding (LSP is complex and not well documented), it may not work the way you want.
It seems that the discussion is getting a bit off-topic :-). A new thread would be better …
I have created an issue for this problem: https://github.com/eclipse/smarthome/issues/6654 . The XTEXT-based LSP server sets nearly all LSP capabilities to “enabled” even if they are not implemented. We probably would have to override the server implementation and set only the currently supported capabilities to “true”.
Hi all,
It seems that the extension works basically, which was the main point i wanted to check before i will push my first release to the marketplace.
I will add the simple mode check for the “Show in Paper UI”-Command and then update the marketplace version.
LSP improvements are already under work and we will have a solution for the topic that was discussed her too in the nearer future hopefully.
Confirmed!
0.4.1 is in the marketplace already (simple mode check included)
It generates a warning message and prevents vscode from opening the browser if simple mode is activated and the user tries to open an item.
For things it opens the browser anyway.
Thank you very much for your work! I just tested it but I have a problem when editing .rules-files. I always get a queer error message like this:
Regardless which .rules-file I open I get this message with thename of the .rules-file.
I am running VSCode on Windows as well as my OH installation (OH 2.4 Snapshot 1407).
Hey @vossivossi,
Does the error only appear or do you have “real problems” in your environment too?
I am really not into that lsp stuff currently and we are refactoring the whole system anyway, so i cant tell you much about it.
If there is just the “duplicate file” error without affecting your system, i would like to leave it for now and see if we can already solve that with the upcoming new implementation.
BR
Jerome
I have seen this message before but this happened when I had two files with nearly similar file names in the rules folder (xxx.1.rules and xxx.rules).
I also can remember that I saw this message one time in my Windows environment
As far as I can see the message comes directly from the LSP. So I don’t think that it is caused by the extension.
Well, I am not sure if this is related to the duplicate file error message but it is also not possible in rules-files to click on a problem in order to get the line of code with the problem. If I click on a problem then I get the next error message that the file cannot be found (although it is open in this very moment and I clicked on a problem message within that file). And with the next mouse click VSCode closes the open rules-File without warning and I am not able to edit it:
So it is not really possible to detect a problem, click on it and edit the problem code. The file will be closed before you can correct it. That is not really expected system behaviour.
However the other functions have improved significantly and I could live with the workaround to not click on problems in the near future…
Yeah, there are many open topics about code validation, syntax checking and code completion currently.
That’s exactly the reason why we decided to give a completely new implementation a try.
This is a really fresh topic and so its under big changes currently but hopefully this will bring us a stable and expandable solution for the future.
Another workaround would be to simply disable the current code checking with the openhab.lspEnabled
setting.
Since you are facing problems anyway, maybe it doesn’t hurt to disable it completely for now.
