Issue of the topic: Openhab running but web interface don’t show… Issue is new after upgrade from 2.4
and new internet provider. but being on LAN can’t se how that should have any effect…
DSM also upgraded but search on the internet show now issues with new DSM
Tried downgrade to 2.4 again and up and down but issue remains …
tryin to acces on 192.168.x.x:8080/start/index - the url shown in package center
Which errors are reported in the openhab.log file ?
Have a look to the release notes at https://github.com/openhab/openhab-distro/releases . Check the section “Breaking Changes that Require Manual Interaction after the Upgrade” and there “REST Docs” in case you have the REST Docs installed.
Manually deleted all files and folders and tried a clean install … result remain the same.
web interface is not opening.
LOGS … hmm the logs found in :/SmartHome/openHAB
2020-08-08 21:41:10> -----------------------------------------------------------------
2020-08-08 21:41:10> called with start
2020-08-08 21:41:10> creating /volume1/SmartHome/openHAB/tmpfs/userdata/logs
2020-08-08 21:41:10> deleting /volume1/SmartHome/openHAB/userdata/logs
2020-08-08 21:41:10> creating /volume1/SmartHome/openHAB/userdata/logs
2020-08-08 21:41:10> linking /volume1/SmartHome/openHAB/tmpfs/userdata/logs to /volume1/SmartHome/openHAB/userdata/logs
2020-08-08 21:41:10> creating /volume1/SmartHome/openHAB/tmpfs/userdata/persistence
2020-08-08 21:41:10> deleting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-08 21:41:10> creating /volume1/SmartHome/openHAB/userdata/persistence
2020-08-08 21:41:10> linking /volume1/SmartHome/openHAB/tmpfs/userdata/persistence to /volume1/SmartHome/openHAB/userdata/persistence
2020-08-08 21:41:10> start: copied Saved to TMPFS
2020-08-08 23:16:20> -----------------------------------------------------------------
2020-08-08 23:16:20> called with stop
2020-08-08 23:16:20> stop: copied TMPFS to Saved
2020-08-08 23:16:20> stop: /volume1/SmartHome/openHAB/userdata/logs is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/logs
2020-08-08 23:16:20> stop: /volume1/SmartHome/openHAB/userdata/persistence is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-08 23:16:20> stop: /volume1/SmartHome/openHAB/tmpfs is mounted => start unmounting /volume1/SmartHome/openHAB/tmpfs
2020-08-08 23:16:20> stop: directory /volume1/SmartHome/openHAB/tmpfs exists => removing
2020-08-09 00:09:03> -----------------------------------------------------------------
2020-08-09 00:09:03> called with start
2020-08-09 00:09:03> creating /volume1/SmartHome/openHAB/tmpfs/userdata/logs
2020-08-09 00:09:03> deleting /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 00:09:03> creating /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 00:09:03> linking /volume1/SmartHome/openHAB/tmpfs/userdata/logs to /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 00:09:03> creating /volume1/SmartHome/openHAB/tmpfs/userdata/persistence
2020-08-09 00:09:03> deleting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 00:09:03> creating /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 00:09:03> linking /volume1/SmartHome/openHAB/tmpfs/userdata/persistence to /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 00:09:03> start: copied Saved to TMPFS
2020-08-09 17:37:15> -----------------------------------------------------------------
2020-08-09 17:37:15> called with stop
2020-08-09 17:37:15> stop: copied TMPFS to Saved
2020-08-09 17:37:15> stop: /volume1/SmartHome/openHAB/userdata/logs is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 17:37:15> stop: /volume1/SmartHome/openHAB/userdata/persistence is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 17:37:15> stop: /volume1/SmartHome/openHAB/tmpfs is mounted => start unmounting /volume1/SmartHome/openHAB/tmpfs
2020-08-09 17:37:15> stop: directory /volume1/SmartHome/openHAB/tmpfs exists => removing
2020-08-09 17:39:54> -----------------------------------------------------------------
2020-08-09 17:39:54> called with start
2020-08-09 17:39:54> creating /volume1/SmartHome/openHAB/tmpfs/userdata/logs
2020-08-09 17:39:54> deleting /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 17:39:54> creating /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 17:39:54> linking /volume1/SmartHome/openHAB/tmpfs/userdata/logs to /volume1/SmartHome/openHAB/userdata/logs
2020-08-09 17:39:54> creating /volume1/SmartHome/openHAB/tmpfs/userdata/persistence
2020-08-09 17:39:54> deleting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 17:39:54> creating /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 17:39:54> linking /volume1/SmartHome/openHAB/tmpfs/userdata/persistence to /volume1/SmartHome/openHAB/userdata/persistence
2020-08-09 17:39:54> start: copied Saved to TMPFS
2020-08-12 12:15:14> -----------------------------------------------------------------
2020-08-12 12:15:14> called with start
2020-08-12 12:15:14> start: directory /volume1/SmartHome/openHAB/tmpfs exists => removing
2020-08-12 12:15:14> creating /volume1/SmartHome/openHAB/tmpfs/userdata/logs
2020-08-12 12:15:14> deleting /volume1/SmartHome/openHAB/userdata/logs
2020-08-12 12:15:14> creating /volume1/SmartHome/openHAB/userdata/logs
2020-08-12 12:15:14> linking /volume1/SmartHome/openHAB/tmpfs/userdata/logs to /volume1/SmartHome/openHAB/userdata/logs
2020-08-12 12:15:14> creating /volume1/SmartHome/openHAB/tmpfs/userdata/persistence
2020-08-12 12:15:14> deleting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-12 12:15:14> creating /volume1/SmartHome/openHAB/userdata/persistence
2020-08-12 12:15:14> linking /volume1/SmartHome/openHAB/tmpfs/userdata/persistence to /volume1/SmartHome/openHAB/userdata/persistence
2020-08-12 12:15:14> start: copied Saved to TMPFS
2020-08-17 21:26:41> -----------------------------------------------------------------
2020-08-17 21:26:41> called with stop
2020-08-17 21:26:41> stop: copied TMPFS to Saved
2020-08-17 21:26:41> stop: /volume1/SmartHome/openHAB/userdata/logs is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/logs
2020-08-17 21:26:41> stop: /volume1/SmartHome/openHAB/userdata/persistence is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-17 21:26:41> stop: /volume1/SmartHome/openHAB/tmpfs is mounted => start unmounting /volume1/SmartHome/openHAB/tmpfs
2020-08-17 21:26:41> stop: directory /volume1/SmartHome/openHAB/tmpfs exists => removing
2020-08-17 22:05:43> -----------------------------------------------------------------
2020-08-17 22:05:43> called with start
2020-08-17 22:05:43> creating /volume1/SmartHome/openHAB/tmpfs/userdata/logs
2020-08-17 22:05:43> deleting /volume1/SmartHome/openHAB/userdata/logs
2020-08-17 22:05:43> creating /volume1/SmartHome/openHAB/userdata/logs
2020-08-17 22:05:43> linking /volume1/SmartHome/openHAB/tmpfs/userdata/logs to /volume1/SmartHome/openHAB/userdata/logs
2020-08-17 22:05:43> creating /volume1/SmartHome/openHAB/tmpfs/userdata/persistence
2020-08-17 22:05:43> deleting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-17 22:05:43> creating /volume1/SmartHome/openHAB/userdata/persistence
2020-08-17 22:05:43> linking /volume1/SmartHome/openHAB/tmpfs/userdata/persistence to /volume1/SmartHome/openHAB/userdata/persistence
2020-08-17 22:05:43> start: copied Saved to TMPFS
2020-08-18 21:45:00> -----------------------------------------------------------------
2020-08-18 21:45:00> called with stop
2020-08-18 21:45:00> stop: copied TMPFS to Saved
2020-08-18 21:45:00> stop: /volume1/SmartHome/openHAB/userdata/logs is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/logs
2020-08-18 21:45:00> stop: /volume1/SmartHome/openHAB/userdata/persistence is mounted => start unmounting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-18 21:45:00> stop: /volume1/SmartHome/openHAB/tmpfs is mounted => start unmounting /volume1/SmartHome/openHAB/tmpfs
2020-08-18 21:45:00> stop: directory /volume1/SmartHome/openHAB/tmpfs exists => removing
2020-08-18 21:54:11> -----------------------------------------------------------------
2020-08-18 21:54:11> called with start
2020-08-18 21:54:11> creating /volume1/SmartHome/openHAB/tmpfs/userdata/logs
2020-08-18 21:54:11> deleting /volume1/SmartHome/openHAB/userdata/logs
2020-08-18 21:54:11> creating /volume1/SmartHome/openHAB/userdata/logs
2020-08-18 21:54:11> linking /volume1/SmartHome/openHAB/tmpfs/userdata/logs to /volume1/SmartHome/openHAB/userdata/logs
2020-08-18 21:54:11> creating /volume1/SmartHome/openHAB/tmpfs/userdata/persistence
2020-08-18 21:54:11> deleting /volume1/SmartHome/openHAB/userdata/persistence
2020-08-18 21:54:11> creating /volume1/SmartHome/openHAB/userdata/persistence
2020-08-18 21:54:11> linking /volume1/SmartHome/openHAB/tmpfs/userdata/persistence to /volume1/SmartHome/openHAB/userdata/persistence
2020-08-18 21:54:11> start: copied Saved to TMPFS
:/SmartHome/openHAB/userdata/logs
2020-08-18 21:58:35.429 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.104:8080
2020-08-18 21:58:35.609 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.104:8443
2020-08-18 21:58:39.302 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-08-22 14:44:48.788 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2020-08-22 14:48:15.620 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-08-22 14:48:20.854 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.104:8080
2020-08-22 14:48:20.863 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.104:8443
ISP delivered range extenders and YES I switched the router but from DLink to New DLink …and router config copy/paste… Also ran the router config toll on Syno … But yes -the devils is in the detail and the router might be the little thing…
but it seams to A-ok… any hints on what to look for
arghh…
router fresh reconfigured and running no problems discovered …other than the web interface from openHAB… it still don’t show…
reinstalled openHAB 2.5.2 -tried in both public and in smarthome folder… see the desperation
java checked= java 8 :vers 1.8.0_261
Used EZ -internet for router config, and like I said every other application on my syno is running fine
Latest log 2020-09-05 19:25:11.600 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.107:8080 2020-09-05 19:25:11.751 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.107:8443 2020-09-05 19:25:16.792 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
http://192.168.0.107:8080… instantly returns with message “can’t open page “192.168.0.107:8080” no respond from server”
funny thing - it used to work before update- tried 2.4.xoxoxo same respons…
Any suggestion welcome… tried oregano on door steep and other funny things so im pretty open for suggestions
Yes IP change due to reconfiguration om router in previous post it vas 192.168.0.104 now 107 instead …just for the verification
over the night LOG show some kind of java error…
tried to reinstall JAVA 8 … still no web page… obvious
2020-09-05 21:10:53.826 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.107:8080
2020-09-05 21:10:53.907 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.107:8443
2020-09-05 21:10:56.495 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-09-06 00:51:43.960 [WARN ] [lipse.jetty.server.AbstractConnector] -
java.lang.UnsatisfiedLinkError: no net in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) ~[?:1.8.0_212]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_212]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_212]
at sun.net.ExtendedOptionsImpl.lambda$static$0(ExtendedOptionsImpl.java:48) ~[?:1.8.0_212]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_212]
at sun.net.ExtendedOptionsImpl.(ExtendedOptionsImpl.java:47) ~[?:1.8.0_212]
at sun.nio.ch.SocketChannelImpl$DefaultOptionsHolder.defaultOptions(SocketChannelImpl.java:242) ~[?:1.8.0_212]
at sun.nio.ch.SocketChannelImpl$DefaultOptionsHolder.(SocketChannelImpl.java:229) ~[?:1.8.0_212]
at sun.nio.ch.SocketChannelImpl.supportedOptions(SocketChannelImpl.java:251) ~[?:1.8.0_212]
at sun.nio.ch.SocketChannelImpl.setOption(SocketChannelImpl.java:169) ~[?:1.8.0_212]
at sun.nio.ch.SocketAdaptor.setBooleanOption(SocketAdaptor.java:271) ~[?:1.8.0_212]
at sun.nio.ch.SocketAdaptor.setTcpNoDelay(SocketAdaptor.java:306) ~[?:1.8.0_212]
at org.eclipse.jetty.server.ServerConnector.configure(ServerConnector.java:402) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.ServerConnector.accepted(ServerConnector.java:394) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.ServerConnector.accept(ServerConnector.java:386) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:664) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
2020-09-06 00:51:53.552 [WARN ] [lipse.jetty.server.AbstractConnector] -
java.lang.NoClassDefFoundError: Could not initialize class sun.nio.ch.SocketChannelImpl$DefaultOptionsHolder
2020-09-06 00:51:54.759 [WARN ] [lipse.jetty.server.AbstractConnector] -
2020-09-06 00:51:56.204 [WARN ] [lipse.jetty.server.AbstractConnector] -
2020-09-06 11:01:37.601 [WARN ] [lipse.jetty.server.AbstractConnector] -
2020-09-06 11:02:26.773 [WARN ] [lipse.jetty.server.AbstractConnector] -
2020-09-06 11:03:00.455 [WARN ] [lipse.jetty.server.AbstractConnector] -
2020-09-06 11:03:04.105 [WARN ] [lipse.jetty.server.AbstractConnector] -
2020-09-06 15:25:58.847 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-09-06 15:26:07.320 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.107:8080
2020-09-06 15:26:07.337 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.107:8443
2020-09-06 15:29:20.045 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
