openHAB ZigBee Binding connect wit sonoff SNZB-02
I want to connect my Sonoff SNZB-02 to my open hab system. i tried to do it via the ZigBee Binding and it does detect the device but only as an Generic Device and then it is offline without any Channels. in the docu it sais that it would be compatible. could someone please help me?
Welcome to the community!
Yes, it is compatible.
I have 3 of them connected and using the zigbee binding.
It does take a few minutes to fully learn the device so be patient.
You may have to rediscover it a few times also.
Check your event log to follow its progress
It is a battery operated device so it does not reply as quick as a mains powered device.
Mine also show as a generic device but under the info you will see info like this
Generic ZigBee Device
hardwareVersion
1
zigbee_datecode
20211103
zigbee_networkaddress
47409
zigbee_zclversion
1
zigbee_lastupdate
zigbee_stkcompliance
0
zigbee_powermode
RECEIVER_ON_PERIODICALLY
zigbee_applicationVersion
5
zigbee_devices
zigbee_powersource
RECHARGABLE_BATTERY
zigbee_logicaltype
END_DEVICE
vendor
eWeLink
zigbee_powerlevel
MEDIUM
zigbee_routes
modelId
TH01
zigbee_manufacturercode
0x0000
zigbee_neighbors
zigbee_device_initialised
true
zigbee_powersources
[RECHARGABLE_BATTERY]
after it is fully discovered.
You may also consider using zigbee2mqtt if you have some of the other devices that are not zigbee standard (this one is btw)
but most that are branded as tuya or other low cost knock off brands are not and the best way for you to implement them is the zigbee2mqtt approach.
