Ok, no more broker hanging in the inbox, but still no humidity in Google Assistant.
And this worning:
Unrecognized heating cooling target mode: heat. Expected CoolOn, HeatOn, Auto, or Off strings in value.
Guessing it expects to have this as a string not number.
You can try a rule to post the value as a string.
rule "Test String"
Item YourHumidityItem changed
YourHumidityItem.postUpdate(YourHumidityItem.state.toString)
If that fails then try using a proxy item for the humidity reading so the rule would change to use (ProxyItem.state.toString) in place of (YourHumidityItem.state.toString)
This for fix the problem in google with Umidity?
Or to fix the problem of the cooling target mode?
anyway I tried the rule, but … no change.
If I put the “String” value directly in the items file? like:
String Humidity items …
