I have a couple of zwave devices already connected, but today I tried to add a Zwave multisensor (ZW074 - AU version).
Adding the device went fine, but the sensor wasnât automatically added to the Inbox in paperui.
Trying to add it manually, the sensor hasnât been detected:
I get a device âZ-Wave Node4â as zwave:device:4d43bf00:node4
Help suggests that either itâs likely missing the device definition in the database - possibly as this is the AU version of the sensor (AU uses a different zwave frequency to other regions).
Any suggestions on how I add this device to the zwave database?
2017-02-02 19:14:23.721 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-02-02 19:14:23.728 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4d43bf00:node4' to inbox.
Thatâs really strange - Iâd need to see a log to understand thisâŠ
What do you mean by adding it manually? Are you trying to define this in the text files - if so, you canât currently define zwave things in the text files at the moment
It seems this comment isnât quite right based on your log below?
I suspect that the device just needs waking up. It looks like it is discovered, and added to the inbox, but based on the fact that the device data is not known I think that the device needs waking up so that the binding can initialise it.
