Kleemann
(Kleemann)
December 8, 2017, 4:21pm
21
Hey,
i think yes. I’ll take a look and when it is installed i’ll uninstall it.
Will reply then again!..
I’ve uninstalled it now and
For the group and even my color-item i still get the information that it is not supported
"[Gruppe] | [Item] unterstützt dies nicht" -> En “[Group] | [Item] does not support that”
Celaeno1
(Alex)
December 8, 2017, 4:38pm
22
@Kleemann
Did you also restart Openhab and also rediscover your devices with Alexa APP?
Kleemann
(Kleemann)
December 8, 2017, 4:49pm
23
Still not working. No new devices found and still not support
Celaeno1
(Alex)
December 8, 2017, 5:46pm
24
@Kleemann
Delete all devices (comming from Openhab) in Alexa APP. Then rediscover them. Put them into Group “Test” again.
If that doesn’t help, I’m out! Sorry!
Kleemann
(Kleemann)
December 8, 2017, 6:05pm
25
I’ve also remove the openHab skill from the alexa app now and now i won’t finde any devices.
I just the only available skill called “Openhab” for Alexa. Any idea?
Btw @Celaeno1 i really appreciate your time spent for me, thanks!
Celaeno1
(Alex)
December 8, 2017, 6:11pm
26
Skill “Openhab for Alexa” Link is activated and “myopenhab cloud service” Link is running. And now, no devices can be found?
See here:
Hello folks,
I had the problem (like many others!) “finding any devices” with Alexa, while using “myopenhab cloud service” and “Official Alexa Smart Home Skill”. After several investigations I found the cause!
EDIT: There were missing labels! --> In my case, there was NO problem with my .items file! (But you better should check it also!)
The missing labels came from here:
If you have set in \conf\services\runtime.cfg the following:
org.eclipse.smarthome.links:autoLinks=true
or via PaperUI: …
If you use “hueemulation” with “Openhab Skill for Alexa”, then NO COLOR is supported!
You have to use “myopenhab cloud service” for changing hue colors.
Kleemann
(Kleemann)
December 8, 2017, 6:26pm
27
Hello @Celaeno1
i don’t know why but now its work.
I think it a typically programmer thing, restart reconfigure and it work.
I thank you so much, really! When you may will be in Berlin sometime, leave me a message and let us get a drink, i pay.
Thanks so much!
EdricEddy
(Edric Eddy)
May 8, 2018, 11:46am
29
I think you have to change your channel definition and i don’t think there is any difference between Alexa App .
