Ihave a question concerining the item defintions.
When I define:
// shows the sunrise
DateTime Sunrise_Time “Sonnenaufgang[%1$tH:%1$tM]” { channel=“astro:sun:home:rise#start” }
DateTime Sunset_Time “Sonnenuntergang [%1$tH:%1$tM]” { channel=“astro:sun:home:set#start” }
String MoonPhase “Mondphase [MAP(astro.map):%s]” { channel=“astro:moon:home:phase#name” }
It works on the sitemap with
Text item=Sunrise_Time icon="sunrise"
Text item=Sunset_Time icon="sunset"
Text item=MoonPhase
But if I define in the items:
DateTime Sunrise_Time “Sunrise [%1$tH:%1$tM]” {astro=“planet=sun, type=rise, property=start”}
DateTime Sunset_Time “Sunset [%1$tH:%1$tM]” {astro=“planet=sun, type=set, property=end”}
It does not work on the seitemap.
What is the difference between these two definitions which I found both in some websites
Thank you
