Dear community,
I am trying to get my head around OpenHab2. I am pretty deep in using Blynk to control my home and I would love to integrate everything into OpenHab2.
However, I am really having trouble connecting via http binding. Here is what I have tried:
rules
rule "Blynk test"
Item blynk_test received command
switch(receivedCommand) {
case ON : sendHttpGetRequest("http://139.59.206.133:8080/[TOKEN]/update/v6?value=500")
case OFF : sendHttpGetRequest("http://139.59.206.133:8080/[TOKEN]/update/v6?value=120")
items
Switch blynk_test "Blynk_Test"
sitemap
sitemap test label="Test"
Frame {
Switch item=blynk_test
This is pretty straight forward and the http command works perfectly from the browser. However, in openhab.log I see the following error:
2017-03-14 13:01:54.786 [ERROR] [.script.engine.ScriptExecutionThread] - Rule ‘Blynk test’: An error occured during the script execution: java/util/function/Consumer
Couple of questions:
- Why do I get the error?
- Is there any way to debug what is happening?
- Any additional thoughts on how I should orgaize the integration? Later on I want to control and measure. So if somebody had an example on how to read values I would be very thankful
Thanks a ton,
Matthias
