I tried to bind the EnOcean add-on with the paper UI but it doesn’t work out. The problem seems to be that the Enocean: binding-enocean1 - 1.12.0
is based on the old openhab 1 and it seems a binding “driver” for openhab2 or 2.3 is still not available.
I read also the hint of [khangelov] to download org.openhab.binding.enocean-1.9.0.jar but I have no idea where I can download it. The download link in the openhab.org documentation is outdated. Is this file and version still valid for openhab2.3 ?
I’m trying to bind a NodOn temperature & Humidity sensor. An items file I have created but the content I puzzled from the http://docs.openhab.org/addons/bindings/enocean1/readme.html as there no example how to combine it with the humidity.
That’s the log output:
_ 2018-11-13 23:38:14.805 [INFO ] [.enocean.internal.bus.EnoceanBinding] - Connecting to Enocean [serialPort=’/dev/ttyUSB0’ ].
2018-11-13 23:38:14.958 [ERROR] [.internal.config.BindingConfigParser] - Could not set value A5:04:01 to attribute eep in class EnoceanBindingConfig
==> /var/log/openhab2/events.log <=_
did you see that an openHAB2 version of the enocean binding got released a few days ago. This binding also already supports the A5-04-01 EEP and autodiscovery.
Hi Daniel (@fruggy83),
thanks for notification.
I have updated openHabian to latest version (still 2.3.0.1) with ‘sudo openhabian-config’ but I could not see any version change in the Enocean binding, still 1.12.
Could you explain to a novice how to update your suggested version ‘binding-enocean - 2.4.0.SNAPSHOT’ ?
I can change from the stable openHAB version (2.3.0.1) to an unstable/Snapshot version with option ‘03’ in openhabian-config. Or you wait until December 17th, then the stable 2.4 version is planned to be released.
maybe you have a special developer version.
In my installed openHAB version (2.3.0.1) I can change in openhabian-config with option ‘03’ to
“03 | openHAB Stable Install or upgrade to the latest stable release of openHAB 2”
It seems I really have to wait till 17th of December?
Best Regards
Stefan
sorry my fault, I misremembered. You first have to switch with open 40 to a snapshot version of openhab. Later on you are able to upgrade your system with option 02.
yes luckily after renewing the linkage in the things configuration or in the .items file, the humidity values were shown too.
To me it looks like there is a general problem that the paper UI cannot synchronize with the .items file definitions.
