I am trying to get the version from the thread title to work but I cant get it.
First, I cant find the ‘start.sh’ in the openhab distribution files from github. I might try openhab 1.8.1 and habmin first, if you guys can help me with that.
Right now, with openhab1.8.1 and habmin I get a ‘403’ when accessing http://openhab ip/habmin2 with one .jar in …/addons and one .jar in …/webapps
edit: I’ve found the ‘start.sh’, now I am getting a startup error
pi@openhab:/opt/openhab-distro/distributions/distribution-resources/src/main/resources/home $ sudo ./start.sh
Launching the openHAB runtime…
./start.sh: 6: exec: ./runtime/karaf/bin/karaf: not found
Could you guys point me to the right direction with this?
It’s a bit difficult to tell, but I suspect you’re mixing up OH1 and OH2 installation instructions. Certainly from a HABmin perspective, if you’re using openhab2, then the installation doesn’t require the webapps folder, and if it’s OH1, then there’s no JAR in the webapps folder, it’s a directory structure…
Since your edit talks about Karaf, then I assume you’re using OH2, in which case, there’s just a single JAR to install (well, 3 JARs since you’ll also need to install zwave, and possibly the serial transport bundle as well).
Yeah I figured that one out already. Used OH1 then but I dont see support for my CUL433/CUL868 devices. since I dont have any other hardware, I guess I cant play with OH, sadly…
