Hi folks.
I’ve got openhab2 installed via openhabian on a Raspberry 3.
I’d like to have the pool pumps run according to a schedule and the schedule should also vary according to the seasons and weather.
It’s a small pool, approx 15kl with sun solar panels for heating. In winter it manages to stay above 20C…oh, I need to mention it is an outside pool but under a polycarb roof.
In the peak of summer, it could hit temperatures of 35C.
Anyways…it has 2x pumps…the normal filtering/circulating pump…the same pump/circuit pushes the water through the solar panels.
I have another slightly smaller pump. The one side of the pool has an infinity look/feel.
So water spilling over falls into a catch area.
In the catchup area, there is a municipal tap installed working on a ball valve.
So…effectively the water catchup area is being kept at a constant level. If water level drops, due to sun evaporation, it get’s filled automatically.
Real smart…ok…I didn’t design this…I inherited it when I bought the house some 3x years ago.
Now, the second pump pumps water from this catchup area back into the pool.
If it overfills…well…then it just runs back into the catchup area.
Now, let mew share you the rule I built to manage this.
After I explained above…you now will see why it makes sense that I run the 2nd pump only for 3x minutes at a time…nothing more needed.
This filling up cycle is referred to as “pool fountain” because when the water is pumped from the catchup area back into the pool it runs through/over a rock effect.
Here is the script and then I’ll explain what is wrong or problematic and where I need help.
//Rule to fill pool with water from reservoir
var Timer filltimer = null
var Timer wpooltimer = null
var Timer spooltimer = null
rule "Fill pool operations"
Time cron "0 1 8 ? * * *" // runs everyday at 08:01
or
Time cron "0 1 17 ? * SUN,MON,TUE,WED *" // runs Sun/Mon/Tues/Wed/Thurs at 17:01
or
Time cron "0 1 18 ? * FRI,SAT *" // runs Fri/Sat at 18:01
GenericMQTTThing_SonoffTestCh2.sendCommand(ON)
logInfo("Pool operations", "Pool fountain switched on!")
filltimer = createTimer(now.plusMinutes(3)) [ |
GenericMQTTThing_SonoffTestCh2.sendCommand(OFF)
filltimer = null
logInfo("Pool operations", "Pool fountain switched off!") ]
//Rule to run pool pump
rule "Run pool pump operations in winter"
Time cron "0 02 9 ? * * *" // runs everday at 09:02
if (LocalSun_Season_SeasonName.state.toString == "SPRING") {
GenericMQTTThing_SonOffTestCh1.sendCommand(ON)
logInfo("Summer pool operations", "Pool pump switched on for 7.5 hours!")
spooltimer = createTimer(now.plusHours(7.5)) [ |
GenericMQTTThing_SonOffTestCh1.sendCommand(OFF)
spooltimer = null
logInfo("Summer pool operations", "Pool pump switched off!") ]
else if (LocalSun_Season_SeasonName.state.toString == "SUMMER") {
spooltimer = null
rule "Run pool pump operations in summer"
Time cron "0 02 10 ? * * *" // runs everday at 10:02
if (LocalSun_Season_SeasonName.state.toString == "AUTUMN") {
logInfo("Winter pool operations", "Pool pump switched on for 4.5 hours!")
wpooltimer = createTimer(now.plusHours(4.5)) [ |
wpooltimer = null
logInfo("Winter pool operations", "Pool pump switched off!") ]
else if (LocalSun_Season_SeasonName.state.toString == "WINTER") {
wpooltimer = null
//Rule to stop pool pump
rule "Stop pool pump operations at 17:00"
Time cron "0 00 17 ? * * *" // stops everday at 17:00 for extra precaution
logInfo("Pool operations", "Pool pump switched off at 17:00 as precaution")
rule "Stop pool pump operations when poor weather"
Channel "LocalWeatherAndForecast_Current_Rain#event" triggered
or
Channel "LocalWeatherAndForecast_Current_Cloudiness#event" triggered
if(LocalWeatherAndForecast_Current_Rain.state as Number > 75) {
logInfo("Pool operations", "Pool pump switched off due to rain") }
else if(LocalWeatherAndForecast_Current_Cloudiness.state as Number > 75) {
logInfo("Pool operations", "Pool pump switched off due to clouds") }
The first portion is where I ensure the pool is always kept full by pumping from the catchup area back into the pool.
The second and third portion is the normal running of the filter pump and here you can see how I check on the seasons to determine how long I want the pump to run for the day. In winter for much shorter time since I don’t swim for leisure in water in less than 26C.
The fourth portion is just precaution to ensure the pool pump will never run after hours.
Now…to get to my current problem…or perhaps my wish…
And this is what is seen in the last/5th portion…
what Im trying to achieve here is to stop the filter pump to run when potentially bad weather is being experienced…such as raining…or dark low clouds.
Because this effects the solar heating and things like this would rather cool down the pool water.
My understanding is the following:
I’m looking at 2x parameters:
- Rain - this i think is the rain figure, so either in mm or perhaps in %,
- cloudiness - this I think is the cloud density also I think in %…not sure.
So from the script, you would see that I set both for 75, which I interpret as 75%.
Once these are exceeded, then the pump shutdown for the day.
But, they are not working.
I’ve got the OPENWEATHERMAP binding installed and working 100%.
But from the script you will noticed that I used the LOCALWEATHER function of openhab. This of course is configured with the correct location info etc.
Could anyone suggest how to perform this or what is wrong with above?
