Did you try like i wrote:i
I think the command is sudo dpkg -i libjna-java_3.2.7-4_armhf instead of sudo dpkg -i libjna-java_3.2.7-d_armhf
I solved the dependency problem by installing a libffi5 and then I can run the command: sudo dpkg -i libjna-java_3.2.7-4_armhf successfully
