Hello dear community
Unfortunately, I have found for my mistakes nothing in the search, maybe I see the forest in front of loud trees but I can not go now.
Following problem.
I have scripts to control and read out my ventilation system, these run on the console among the users openhabian and openhab without errors.
But in the interface (BasicUI) they do not work unfortunately.
The following error messages always occur in the log:
2017-07-10 20:04:15.915 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command '0' for item 'lueftung_switch' to handler for channel 'exec:command:lueftungstatus:output', because no thing with the UID 'exec:command:lueftungstatus' could be found.
2017-07-10 20:04:15.926 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command '0' for item 'lueftung_switch' to handler for channel 'exec:command:lueftungschalten:input', because no thing with the UID 'exec:command:lueftungschalten' could be found.
2017-07-10 20:04:15.929 [ItemCommandEvent ] - Item 'lueftung_switch' received command 0
2017-07-10 20:04:15.940 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '0' for item 'lueftung_switch' to handler for channel 'exec:command:lueftungstatus:output', because no thing with the UID 'exec:command:lueftungstatus' could be found.
2017-07-10 20:04:15.945 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update '0' for item 'lueftung_switch' to handler for channel 'exec:command:lueftungschalten:input', because no thing with the UID 'exec:command:lueftungschalten' could be found.
2017-07-10 20:05:16.419 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command '0' for item 'lueftung_modus' to handler for channel 'exec:command:lueftungmodus1:output', because no thing with the UID 'exec:command:lueftungmodus1' could be found.
2017-07-10 20:05:16.422 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate command '0' for item 'lueftung_modus' to handler for channel 'exec:command:lueftungmodus_schalten1:input', because no thing with the UID 'exec:command:lueftungmodus_schalten1' could be found.
.thing
Thing exec:command:lueftungschalten [ command="/bin/bash /home/openhabian/scripts/lueftung_schalten.sh %2$s", interval=0, timeout=20, autorun=false ]
Thing exec:command:lueftungstatus [ command="/bin/bash /home/openhabian/scripts/lueftung_schalten.sh", interval=10, timeout=30, autorun=true ]
Thing exec:command:lueftungmodus_schalten1 [ command="/bin/bash /home/openhabian/scripts/lueftung_modus_schalten.sh %2$s", interval=30, timeout=30, autorun=false ]
Thing exec:command:lueftungmodus1 [ command="/bin/bash /home/openhabian/scripts/lueftung_modus_schalten.sh", interval=30, timeout=30, autorun=true ]
.item
String lueftung_switch "Status" <fan> [ "Switchable" ] { channel="exec:command:lueftungschalten:input", channel="exec:command:lueftungstatus:output", autoupdate="true" }
String lueftung_modus "Modus" <settings> { channel="exec:command:lueftungmodus_schalten1:input", channel="exec:command:lueftungmodus1:output", autoupdate="false" }
.sitemap
sitemap lueftung label="Lüftung"
Frame label="Lüftung Schalten" {
Switch item=lueftung_switch mappings=[ "0"="Strom", "1"="Akku", "2"="Aus" ]
Switch item=lueftung_modus mappings=[ "0"="Automatik", "1"="Manuell" ]
Where is my mistake?
I am grateful for any help and advice
I use the following bindings.
Exec Binding
binding-exec - 2.1.0
Exec Binding (1.x)
binding-exec1 - 1.10.0
Greetings Tobi
