Dear all,
I got OH2 on raspberryPi3+zme_uzb1 and z-wave works fine with aeon minimote and zme_kfob. I stuck with Inclusion of Fibaro FGS222 RU v2.2. It shows like Node6 unknown device in HABmin and can’t be recognised.
What i did:controller hard reset, FGS222 reset, Inclusion/exclusion, heal and reinitialise the device in HABmin.
In complete despair I installed z-way-server and my switch was successfuly connected and configured.
Looks like it possible to use FGS222 with OH, but what i did wrong or how do i can fix it?
Log:
2017-04-01 19:42:58.997 [ERROR] [ve.internal.protocol.ZWaveController] - Neither inclusion nor exclusion was active!
2017-04-01 19:43:05.541 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘zwave:device:15b2a282ebb:node6’ to inbox.
2017-04-01 19:43:05.567 [WARN ] [rialmessage.IdentifyNodeMessageClass] - Got IdentifyNodeMessage without request, ignoring. Last message was SendData.
2017-04-01 19:43:10.565 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Timeout while sending message. Requeueing - 2 attempts left!
2017-04-01 19:43:10.566 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2017-04-01 19:43:10.719 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! 010F:0202:4002::2.2
2017-04-01 19:43:11.561 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Initialising Thing Node…
2017-04-01 19:44:12.812 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 6: Timeout while sending message. Requeueing - 0 attempts left!
2017-04-01 19:44:12.823 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 6: Got an error while sending data. Resending message.
2017-04-01 19:44:13.126 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! 010F:0202:4002::2.2
Hi Chris,
Thank you for fast answer!
I am new to openHAB2 and what i need to do to get this database update from you?
i did reinclusion and OH2 service restart.
Currently there’s a problem with the build system so the updates aren’t working. Once it is sorted, then you should just be able to uninstall the zwave binding, and install it again (so long as you are using the snapshot runtime).
Did you manage to integrate the double switch into your Z-Wave network?
I am currently trying this with the FGS-222 but it does not show up in my inbox. This is what I have done:
In the PaperUI searched for new Z-Wave devices
Pressed the “B” button on the Fibaro switch
This was not successful so I pressed the button for 3 seconds to reset the switch and repeated the above - no success
Connected the “L” inlet with the S1 port with a wire 3 times (to add the device as alternative to pushing the “B” button) - no success
Any ideas? Could you describe your procedure?
Many thanks,
Jonas
