Hi, I am a new user of openhab2, and need some help (link to understandable documentation will be fine too ) in configuring items to receive states of relays and change does states using MQTT.
Platform information:
- Hardware: raspberry pi 3
- OS: openhabian
- Java Runtime Environment:
- openHAB version:2.4
Devices : ESP32 controllers with relay cards
I saw a lot of topics concerning migration form older versions of openhanded to newer versions.
However my problem is much easier, as i am new and started with openhab2.4
I am also confused about the different types of configuration, some times i read about config files sometimes i see configs based on paper, or even see code snippets with config data which are not formatted as i can see in my own config files.
So could someone help me in setting up the following :
I have a mosquitto MQTT broker installed and it works.
I install the MQTT bindings.
i defined a bridge and it is online
When I try to configure things, items or chanels, using that bridge, they are offline and i get an error message : no MQTT client
on the mosquitto log i sees that the openhanded server gets and sends kind of pings
bit not subscription or publishing data
What i want is the following :
i have a light switch and a pump switch.
I want to see the state of the 2 switches ( this is published by the esp32 board, so i have to subscribe to that topic) .
Also, i want to change that state from openhab so have to publish it
Any help ?
