My fresh openhab2 Installation with openhabian crashes every 2 days.
And I don’t know where to find the error.
this is the open.log:
tail -f /var/log/openhab2/openhab.log
java.lang.OutOfMemoryError: Java heap space
2018-11-08 06:30:18.748 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception
2018-11-08 07:16:14.812 [WARN ] [e.jetty.util.thread.QueuedThreadPool] -
2018-11-08 07:16:14.818 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - Unexpected thread death: org.eclipse.jetty.util.thread.QueuedThreadPool$2@17f13e8 in HttpClient@18689837{STARTED,8<=8<=200,i=1,q=0}
2018-11-08 07:20:24.933 [WARN ] [l.LateInvalidatingHashSessionManager] - Problem scavenging sessions
if I request the status with :
sudo systemctl status openhab2.service
I get the following output:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2018-11-09 11:03:55 CET; 4s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 17668 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Process: 17548 ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE (code=exited, status=1/FAILURE)
Main PID: 17548 (code=exited, status=1/FAILURE)
Nov 09 11:03:55 openHABianPi systemd[1]: openhab2.service: Control process exited, code=exited status=1
Nov 09 11:03:55 openHABianPi systemd[1]: openhab2.service: Unit entered failed state.
Nov 09 11:03:55 openHABianPi systemd[1]: openhab2.service: Failed with result ‘exit-code’.
Thank you for any help
