I am trying to setup my rfxcom usb adapter on /dev/ttyUSB0.
I add it as a thing manually using “RFXCOM USB Transceiver” and set the serial port to “/dev/ttyUSB0”.
The thing shows up in the list as offline.
Then I get the error below on the console and openhab2 crashes.
/jni/linux/arm-hf/libjd2xx.so
/usr/bin/java: symbol lookup error: /home/pi/java/openhab2/userdata/tmp/libNRJavaSerial_HF_pi_0/libNRJavaSerial_HF.so: undefined symbol: __fdelt_chk
Any idea what is wrong?
