Some of my Time cron do not seem to work anymore.
e.g.
cron “0 0/1 * 1/1 * ? *” should trigger every minute but does not work
cron “0 0/5 * * * ?” should trigger every 5 minutes is working
cron “0 1 1 * * ?” should trigger one minute past 1 o’clock is not working
I discovered a related issue.
I have a simple rule that should only be started at startup
rule "system startup"
System started
sendCommand(main,ON)
sendCommand(Geburt_name,"")
postUpdate(Delayed_Start,OFF)
createTimer(now.plusSeconds(180)) [|sendCommand(Delayed_Start,ON)]
But as the event log shows it is triggered at one minute past one in the night.
2016-11-22 01:01:00.024 [ItemCommandEvent ] - Item 'main' received command ON
2016-11-22 01:01:00.031 [ItemCommandEvent ] - Item 'Geburt_name' received command
2016-11-22 01:01:00.040 [ItemStateChangedEvent ] - Delayed_Start changed from ON to OFF
Nowhere else the item main is changed in my code. It is absolutely clear that this rule was triggered.
Note: I have indeed a Time cron event that is triggered at one minute past one. But this rule is only triggered when system is started and then no further
Time cron "0 1 1 * * ?" or
System started
I have the feeling that the assignment of cron triggers is not properly done to related rules.
Also note: I have a pretty long rules file which has about 2400 lines of code.
Another example is the following rule
rule "Uhr incrementieren"
when Time cron "0 0/1 * * * ?" or
System started
sendCommand(Uhr,new DateTimeType())
As the event log shows this rule is only triggered at system startup but not every minute
2016-11-21 20:35:20.123 [ItemCommandEvent ] - Item 'Uhr' received command 2016-11-21T20:35:20.115+0100
I discovered a syntax error in the 3rd example. I have been using two times “when”.
After remove the “when” the 3rd example continued to work.
Strangely no error was flagged in the log.
I do not know whether this syntax error has effect of the other timers.
In general, the log is basically not usable from a users point of view. It provides endless Java errors provides hardly a clue where the error was cause in the DSL of the user.
It seems that OH2 Timers are not working if the same timer is used in different rules.
logInfo("erstes Timerue","eins")
logInfo("zweite Timerue","zwei")
in Log I am receiving
10:14:00.034 [INFO ] [marthome.model.script.erstes Timerue] - eins
10:14:00.079 [INFO ] [marthome.model.script.erstes Timerue] - eins
and a third rule, having this timer is not triggered at all.
Remove these two rules and not restarting OH2 does not recover the not triggered rule
Which git hub would this issue to be added.
It is always frustating creating an issue which is immediately closed by Kai due to the wrong issue tracker.
I don’t do this to offend, just to guide you as mentioned here: “But do not worry - if you are not clear, which category your issue belongs to - we will redirect you, if necessary.”
Usually a good hint are the classnames of the logger: In the case of cron scheduled rules, you will find “org.eclipse.smarthome” in most logging statements, so ideally this goes to https://github.com/eclipse/smarthome/issues.
But @sihui is right: In case of doubt, the openhab-distro is always the best option to go for.
