Wow are you the owner of an apartment complex?
Nope, just a 2 family-house with used cellar-rooms
Hi guys,
succesfully set up my new RasPi3 with openhabian! So openhab 2is running and I already installed Homegear and made the settings described here https://doc.homegear.eu/data/homegear-homematicbidcos/configuration.html#config-hm-mod-rpi-pcb (5.2.5). Also I already entered my RasPi3 IP in the Homegear settings (bridge).
I launched PaperUI and everything looks fine, but now I don´t know how to discover/pair my homegear device. I just pressed the âconfigâ button on the device (a roller shutter switch) and hoped it would apper in my Paper UI inbox, what not happened. This is what I got now:
Please help me with the next steps, don´t get it how to add the deviceâŚ
As Thom explained, there are multiple ways to pair your devices.
I would recommend using the CLI.
To do so, you ssh into openhabian and use the following commands:
sudo homegear -r
fs 0
pon
then you should bring the device in pairing mode
sorry, forgot to mention that I already tried that, but I had no success:
do you edited homematicbidcos.conf (5.2.5.2) and restartet homegear?
aargh, dammit. missed that step
thanks for your quick support, will go on now and report back
edit: Ok, that worked now, unfortunately pairing doesn´t
maybe you understand what the debug log says, this is a snapshot of the 60 seconds in paring mode on:
02/24/17 22:25:00.871 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
02/24/17 22:25:10.511 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:25:10.511 RPC Server (Port 2001): Info: Client number 86 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:25:10.512 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
(String) Homegear default BidCoS interface
02/24/17 22:25:10.512 RPC Server (Port 2001): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433034363836353400000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722064656661756C7420426964436F5320696E74657266616365
02/24/17 22:25:10.924 RPC Server (Port 2001): Debug: Packet received: 42696E000000002F00000004696E697400000001000000030000001B62696E6172793A2F2F3139322E3136382E312E3136363A39313236
02/24/17 22:25:10.925 RPC Server (Port 2001): Info: Client number 86 is calling RPC method: init (2) Parameters:
(String) binary://192.168.1.166:9126
02/24/17 22:25:10.925 Info: Removing server "binary://192.168.1.166".
02/24/17 22:25:10.926 RPC Server (Port 2001): Response:
(void)
02/24/17 22:25:10.926 RPC Server (Port 2001): Response binary:
42696E01000000080000000300000000
02/24/17 22:25:10.930 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000004696E697400000002000000030000001B62696E6172793A2F2F3139322E3136382E312E3136363A39313236000000030000000B52462D6231323133666336
02/24/17 22:25:10.931 RPC Server (Port 2001): Info: Client number 86 is calling RPC method: init (2) Parameters:
(String) RF-b1213fc6
02/24/17 22:25:10.931 Info: Adding server "binary://192.168.1.166".
02/24/17 22:25:10.932 RPC Server (Port 2001): Response:
(void)
02/24/17 22:25:10.932 Info: Calling init methods on server "binary://192.168.1.166".
02/24/17 22:25:10.932 RPC Server (Port 2001): Response binary:
02/24/17 22:25:10.935 RPC Server (Port 2001): Info: Connection to client number 86 closed (3).
02/24/17 22:25:10.981 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/24/17 22:25:11.001 Debug: Sleeping 2630ms before sending response.
02/24/17 22:25:11.432 RPC client: Info: Calling RPC method "system.listMethods" on server binary://192.168.1.166.
02/24/17 22:25:11.432 RPC client: Parameters:
02/24/17 22:25:11.432 Debug: Calling getFileDescriptor...
02/24/17 22:25:11.432 Debug: Connecting to host 192.168.1.166 on port 9126...
02/24/17 22:25:11.433 Debug: Connected to host 192.168.1.166 on port 9126. Client number is: 91
02/24/17 22:25:11.433 RPC client: Debug: Sending packet: 42696E000000001A0000001273797374656D2E6C6973744D6574686F647300000000
02/24/17 22:25:11.434 RPC client: Debug: Packet received: 42696E01000000540000010000000004000000030000001073797374656D2E6D756C746963616C6C00000003000000056576656E74000000030000000D64656C65746544657669636573000000030000000A6E657744657669636573
02/24/17 22:25:11.434 RPC client: Debug: Received packet from server 192.168.1.166: 42696E01000000540000010000000004000000030000001073797374656D2E6D756C746963616C6C00000003000000056576656E74000000030000000D64656C65746544657669636573000000030000000A6E657744657669636573
02/24/17 22:25:11.434 RPC client: Response was:
(Array length=4)
(String) system.multicall
(String) event
(String) deleteDevices
(String) newDevices
02/24/17 22:25:11.434 Debug: Adding method system.multicall
02/24/17 22:25:11.434 Debug: Adding method event
02/24/17 22:25:11.434 Debug: Adding method deleteDevices
02/24/17 22:25:11.434 Debug: Adding method newDevices
02/24/17 22:25:13.632 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/24/17 22:25:13.732 UPnP Server: Debug: Sending notify packets.
02/24/17 22:25:13.732 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/24/17 22:25:13.752 Debug: Sleeping 2496ms before sending response.
02/24/17 22:25:16.249 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/24/17 22:25:16.349 UPnP Server: Debug: Sending notify packets.
02/24/17 22:25:16.680 Info: CLI connection accepted. Client number: 92
02/24/17 22:25:16.680 Listening for incoming commands from client number 92.
02/24/17 22:25:25.517 RPC Server (Port 2001): Info: Connection from 192.168.1.166:34492 accepted. Client number: 93
02/24/17 22:25:25.518 RPC Server (Port 2001): Info: RPC server client id for client number 93 is: 14
02/24/17 22:25:25.519 RPC Server (Port 2001): Listening for incoming packets from client number 93.
02/24/17 22:25:25.519 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:25:25.520 RPC Server (Port 2001): Info: Client number 93 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:25:25.520 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:25:25.521 RPC Server (Port 2001): Response binary:
02/24/17 22:25:29.835 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
02/24/17 22:25:29.835 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
02/24/17 22:25:31.836 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
02/24/17 22:25:31.836 Debug: GPIO 18 set to 0.
02/24/17 22:25:31.937 Debug: GPIO 18 set to 1.
02/24/17 22:25:31.973 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 000C000000436F
02/24/17 22:25:31.973 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 000C000000436F
02/24/17 22:25:31.973 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 4350555F424C72
02/24/17 22:25:31.973 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 4350555F424C72
02/24/17 22:25:40.525 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:25:40.526 RPC Server (Port 2001): Info: Client number 93 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:25:40.526 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:25:40.527 RPC Server (Port 2001): Response binary:
02/24/17 22:25:49.949 RPC Server (Port 2001): Debug: Joining read thread of client 13
02/24/17 22:25:49.949 RPC Server (Port 2001): Debug: Client 13 removed.
02/24/17 22:25:55.531 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:25:55.531 RPC Server (Port 2001): Info: Client number 93 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:25:55.532 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:25:55.533 RPC Server (Port 2001): Response binary:
02/24/17 22:26:01.938 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
02/24/17 22:26:02.520 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/24/17 22:26:02.541 Debug: Sleeping 2863ms before sending response.
02/24/17 22:26:02.999 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
02/24/17 22:26:03.000 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
02/24/17 22:26:05.000 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
02/24/17 22:26:05.001 Debug: GPIO 18 set to 0.
02/24/17 22:26:05.101 Debug: GPIO 18 set to 1.
02/24/17 22:26:05.137 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 000C000000436F
02/24/17 22:26:05.137 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 000C000000436F
02/24/17 22:26:05.137 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 4350555F424C72
02/24/17 22:26:05.138 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 4350555F424C72
02/24/17 22:26:05.404 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/24/17 22:26:05.505 UPnP Server: Debug: Sending notify packets.
02/24/17 22:26:05.506 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/24/17 22:26:05.526 Debug: Sleeping 2243ms before sending response.
02/24/17 22:26:07.769 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/24/17 22:26:07.870 UPnP Server: Debug: Sending notify packets.
02/24/17 22:26:10.537 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:26:10.538 RPC Server (Port 2001): Info: Client number 93 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:26:10.538 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:26:10.538 RPC Server (Port 2001): Response binary:
02/24/17 22:26:10.976 RPC Server (Port 2001): Debug: Packet received: 42696E000000002F00000004696E697400000001000000030000001B62696E6172793A2F2F3139322E3136382E312E3136363A39313236
02/24/17 22:26:10.977 RPC Server (Port 2001): Info: Client number 93 is calling RPC method: init (2) Parameters:
02/24/17 22:26:10.977 Info: Removing server "binary://192.168.1.166".
02/24/17 22:26:10.978 RPC Server (Port 2001): Response:
(void)
02/24/17 22:26:10.978 RPC Server (Port 2001): Response binary:
02/24/17 22:26:10.982 RPC Server (Port 2001): Debug: Packet received: 42696E000000004200000004696E697400000002000000030000001B62696E6172793A2F2F3139322E3136382E312E3136363A39313236000000030000000B52462D6231323133666336
02/24/17 22:26:10.982 RPC Server (Port 2001): Info: Client number 93 is calling RPC method: init (2) Parameters:
02/24/17 22:26:10.983 Info: Adding server "binary://192.168.1.166".
02/24/17 22:26:10.984 RPC Server (Port 2001): Response:
(void)
02/24/17 22:26:10.984 Info: Calling init methods on server "binary://192.168.1.166".
02/24/17 22:26:10.984 RPC Server (Port 2001): Response binary:
02/24/17 22:26:10.989 RPC Server (Port 2001): Info: Connection to client number 93 closed (3).
02/24/17 22:26:11.484 RPC client: Info: Calling RPC method "system.listMethods" on server binary://192.168.1.166.
02/24/17 22:26:11.485 RPC client: Parameters:
02/24/17 22:26:11.485 Debug: Calling getFileDescriptor...
02/24/17 22:26:11.485 Debug: Connecting to host 192.168.1.166 on port 9126...
02/24/17 22:26:11.486 Debug: Connected to host 192.168.1.166 on port 9126. Client number is: 98
02/24/17 22:26:11.486 RPC client: Debug: Sending packet: 42696E000000001A0000001273797374656D2E6C6973744D6574686F647300000000
02/24/17 22:26:11.487 RPC client: Debug: Packet received: 42696E01000000540000010000000004000000030000001073797374656D2E6D756C746963616C6C00000003000000056576656E74000000030000000D64656C65746544657669636573000000030000000A6E657744657669636573
02/24/17 22:26:11.488 RPC client: Debug: Received packet from server 192.168.1.166: 42696E01000000540000010000000004000000030000001073797374656D2E6D756C746963616C6C00000003000000056576656E74000000030000000D64656C65746544657669636573000000030000000A6E657744657669636573
02/24/17 22:26:11.488 RPC client: Response was:
(Array length=4)
(String) event
(String) newDevices
02/24/17 22:26:11.488 Debug: Adding method system.multicall
02/24/17 22:26:11.488 Debug: Adding method event
02/24/17 22:26:11.489 Debug: Adding method deleteDevices
02/24/17 22:26:11.489 Debug: Adding method newDevices
02/24/17 22:26:25.543 RPC Server (Port 2001): Info: Connection from 192.168.1.166:34520 accepted. Client number: 99
02/24/17 22:26:25.544 RPC Server (Port 2001): Info: RPC server client id for client number 99 is: 15
02/24/17 22:26:25.545 RPC Server (Port 2001): Listening for incoming packets from client number 99.
02/24/17 22:26:25.545 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:26:25.545 RPC Server (Port 2001): Info: Client number 99 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:26:25.545 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:26:25.546 RPC Server (Port 2001): Response binary:
02/24/17 22:26:35.101 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
02/24/17 22:26:36.168 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
02/24/17 22:26:36.168 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
02/24/17 22:26:38.169 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
02/24/17 22:26:38.170 Debug: GPIO 18 set to 0.
02/24/17 22:26:38.270 Debug: GPIO 18 set to 1.
02/24/17 22:26:38.306 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 000C000000436F
02/24/17 22:26:38.306 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 000C000000436F
02/24/17 22:26:38.306 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 4350555F424C72
02/24/17 22:26:38.307 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 4350555F424C72
02/24/17 22:26:40.552 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:26:40.553 RPC Server (Port 2001): Info: Client number 99 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:26:40.553 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:26:40.554 RPC Server (Port 2001): Response binary:
02/24/17 22:26:49.977 RPC Server (Port 2001): Debug: Joining read thread of client 14
02/24/17 22:26:49.977 RPC Server (Port 2001): Debug: Client 14 removed.
02/24/17 22:26:54.542 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/24/17 22:26:54.562 Debug: Sleeping 1660ms before sending response.
02/24/17 22:26:55.557 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:26:55.558 RPC Server (Port 2001): Info: Client number 99 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:26:55.558 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:26:55.558 RPC Server (Port 2001): Response binary:
02/24/17 22:26:56.223 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/24/17 22:26:56.323 UPnP Server: Debug: Sending notify packets.
02/24/17 22:26:56.324 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
02/24/17 22:26:56.344 Debug: Sleeping 469ms before sending response.
02/24/17 22:26:56.813 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
02/24/17 22:26:56.914 UPnP Server: Debug: Sending notify packets.
02/24/17 22:27:08.271 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
02/24/17 22:27:09.333 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
02/24/17 22:27:09.333 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
02/24/17 22:27:10.562 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:27:10.562 RPC Server (Port 2001): Info: Client number 99 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:27:10.563 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:27:10.563 RPC Server (Port 2001): Response binary:
02/24/17 22:27:11.028 RPC Server (Port 2001): Debug: Packet received: 42696E000000002F00000004696E697400000001000000030000001B62696E6172793A2F2F3139322E3136382E312E3136363A39313236
02/24/17 22:27:11.028 RPC Server (Port 2001): Info: Client number 99 is calling RPC method: init (2) Parameters:
02/24/17 22:27:11.029 Info: Removing server "binary://192.168.1.166".
02/24/17 22:27:11.029 RPC Server (Port 2001): Response:
(void)
02/24/17 22:27:11.030 RPC Server (Port 2001): Response binary:
02/24/17 22:27:11.334 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connected to HM-MOD-RPI-PCB.
02/24/17 22:27:11.335 Debug: GPIO 18 set to 0.
02/24/17 22:27:11.435 Debug: GPIO 18 set to 1.
02/24/17 22:27:11.470 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 000C000000436F
02/24/17 22:27:11.471 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 000C000000436F
02/24/17 22:27:11.471 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (3). Trying to reconnect...
02/24/17 22:27:12.471 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
02/24/17 22:27:22.321 Connection to client number 92 closed.
02/24/17 22:27:25.568 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
02/24/17 22:27:25.569 RPC Server (Port 2001): Info: Client number 99 is calling RPC method: listBidcosInterfaces (2) Parameters:
02/24/17 22:27:25.569 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC0468654
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
02/24/17 22:27:25.570 RPC Server (Port 2001): Response binary:
you have to enter pon
, then bring your device into pairing mode (check manual), then youâll see the device in the list shown by the command ls
. You can then even name the device if you like: pn 1 Switch xyz
If pairing didnât succeed yet, just try again.
Your log canât tell us much, other than that your module seems to be tranceiving, which is a good start.
Ok, reinstalled everything a few times, now it´s working very fine! In the end I must say it was quiet easy, just a little tricky here and there.
Thanks for your help!!
Hi, for the past 2 weeks Iâm trying to instal openhabian, homegear, HMâMODâRPIâPCB on PaspberryPi 3 with WiFi on and I cannot succeed. Iâve done all steps in the whole google but nothing⌠my HMâMODâRPIâPCB is with RTC-Clock (homematic-guru.de/wp-content/uploads/2017/11/Funkmodul_RTC_Homematic_RaspberryMatic_CCU2_Raspberry_2.png)
step1 - flashing the latest official openhabian 1.4 and importing wifi settings in the openhabian.conf before first run
step2 - ssh login with openhabian for username and pass (waithing till first run setup to be done)
step3 - openhabian-config - update, update software add additinal packages, install homegear, disabling serial,disable bt, and no star on addâŚ
step4 - /etc/homegear/families/homematicbidcos.conf - configurating so i have the fs 0 option for my HMâMODâRPIâPCB device, editing the /boot/cmdline.txt (dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait), /boot/config.txt (enable_uart=1 , dtparam=spi=on , dtparam=i2c_arm=on , dtoverlay=pi3-miniuart-bt)
step5 - restart
step6 - sudo su, homegera -r, fs 0, pon = NOTHING
step7 - scream! (http://i0.kym-cdn.com/entries/icons/original/000/012/073/7686178464_fdc8ea66c7.jpg)
the Raaspberry 3 + HMâMODâRPIâPCB + WiFi configuration is working with raspberrymatic without problems!!
can someone give me a working openhabian+homegear+HMâMODâRPIâPCB .img file for rpi3 PLEASE!
Thank You!
The long story short (openhabian, homegear, HMâMODâRPIâPCB with RTC-Clock on PaspberryPi 3 with WiFi
Flash openhabianpi-raspbian-201712171718-git30faec3-crccc053823.img to Verbatim 16GB MicroSD Class 10 with Win32 Disk Image
Befor putting the card in the RaspberryPi 3 edit openhabian.conf and add:
wifi_ssid="WIFIName"
wifi_psk=âPASSWORDâ -
Put the SD card in the RaspberryPi 3 (no LAN cabe/power on) and after 2 min find the device IP in your network with some NetworkScanner
Connect to the device IP with putty (SSH connection)
username=openhabian
password=openhabian
now waith till end of the starting instalation script (~20 minutes, depends and on your internet connection), than press CTRL+C to get back to the console -
Type sudo su and enter the password (openhabian), than start openhabian-config
In openhabian-config go to:
01 | Update Pull the latest revision of the openHABian Configuration Tool
02 | Upgrade System Upgrade all installed software packages to their newest version -
In openhabian-config:
30 | System Settings A range of system and hardware related configuration steps
-35 | Serial Port Prepare serial ports for peripherals like Razberry, SCC, Pine64 ZWave, âŚ
â [] 1 (RPi) Disable serial console (Razberry, SCC, Enocean)
â [] 2 (RPi3) Disable Bluetooth module (Razberry)
â [ ] 3 Add common serial ports to openHAB JVM (Razberry, Enocean)
press enter
8.In openhabian-config:
20 | Optional Components Choose from a set of optional software components
-26 | Homegear Homematic specific, the CCU2 emulation software Homegear
and install Homegear, than exit openhabian-config
- Edit homematicbidcos.conf ânano /etc/homegear/families/homematicbidcos.confâ like this (uncomment - delete the # in front of the text fields under every !!! mark):
########### HM-MOD-RPI-PCB ###########
The device family this interface is for !!!
[HomeMatic Wireless Module for Raspberry Pi]
Specify an unique id here to identify this device in Homegear !!!
id = My-HM-MOD-RPI-PCB
When default is set to âtrueâ Homegear will assign this device
to new peers.
#default = true
Options: cul, cc1100, coc, cunx, hmcfglan, hmlgw, hm-mod-rpi-pcb, homegeargateway !!!
deviceType = hm-mod-rpi-pcb
device = /dev/ttyAMA0
Default: responseDelay = 95
Should be â95â for CUL or COC, â100â for TI CC1101 and â60â for HM-CFG-LAN or HM-LGW !!!
responseDelay = 95
Default: gpio1 = 0
â18â for HM-MOD-RPI-PCB !!!
gpio1 = 18
now press CTRL+X, than âyâ, than enter
- Edit cmdline.txt ânano /boot/cmdline.txtâ to look like this:
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=005b14ef-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
- Edit config.txt ânano /boot/config.txtâ and uncomment (delete the # in front of the lines, again look for my marks !!! here):
For more options and information see
http://rpf.io/configtxt
Some settings may impact device functionality. See link above for details
uncomment if you get no picture on HDMI for a default âsafeâ mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be displayâs size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Uncomment some or all of these to enable the optional hardware interfaces !!!
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835) !!!
dtparam=audio=on
gpu_mem=16
enable_uart=1
Restart the RaspberryPi 3 ârebootâ
Test Homegear and the HM-MOD-RPI-PCB device by entering:
homegear -r
fs 0
pon
put your device in connection mode (how to do that depends on your peripheral device, so read your device manual)
- ??? nothing ??? what ??? how ??? why ??? ?!%@!@&!! ??? now what?
by the way:
################# openHABianPi ################################################
Ip = 192.168.10.119
Release = Raspbian GNU/Linux 9 (stretch)
Kernel = Linux 4.9.59-v7+
Platform = Raspberry Pi 3 Model B Rev 1.2
Uptime = 0 day(s). 0:0:42
CPU Usage = 46.85 % avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 2.02, 5m: 0.54, 15m: 0.19
Memory = Free: 0.67GB (71%), Used: 0.27GB (29%), Total: 0.95GB
Swap = Free: 0.09GB (100%), Used: 0.00GB (0%), Total: 0.09GB
Root = Free: 11.63GB (85%), Used: 1.92GB (15%), Total: 14.16GB
Updates = 0 apt updates available.
Sessions = 1 sessions
Processes = 132 running processes of 32768 maximum processes
Welcome to __ _____ ____ _
____ ____ ___ ____ / / / / | / __ )(_)___ _____
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ / / __ `/ __ \
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ / / /_/ / / / /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/_/\__,_/_/ /_/
/_/
openHAB 2.2.0-1 (Release Build)
Thank you so much for this detailed walkthrough which is exactly what a NOOB like myself needs!! Does it apply to the new RPI-FR-MOD in a RPI B+ as well?
Hi Georgi,
Thank you for your post, it did sure helped me to move forward a lot.
I have tried it with my new RPI4, and freshly downloaded Openhabian. Unfortunately the result was the same: no devices dicovered.
I sorted the issue by installing the Pivccu3, that runs nicely and I could even easy look up the status of the radio module to eliminate problems there.
