OpenHab run on RPi4. The items are set to read values using the http binding 1.14.0. Doing dmesg on the RPi4 it reports lots of errors mmc0.
Platform information:
- RPi with openhabian and openHAB 2.5.0~S1549-1 (Build #1549)
- Some 20 items use the HTTP Binding “binding-http1 - 1.14.0”, with from 1 to 10s refresh rate
- Web-server runs on the same RPi, responding to all requests from HTTP Binding
Example item (~ 20 in total):
Number XT_invVoltInV12 "AC voltage in V12[%d V]" { http="<[http://<ip:port>/invVoltInV12:1000:JSONPATH($.invVoltInV12)]" }
Error excerpt from dmesg (there are some 100 lines spread over 5 days , from second 7777 to today at 412000 secs):
[258933.125342] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[258933.125351] mmc0: sdhci: Caps: 0x45ee6432 | Caps_1: 0x0000a525
[258933.125360] mmc0: sdhci: Cmd: 0x00000c1b | Max curr: 0x00080008
[258933.125369] mmc0: sdhci: Resp[0]: 0x00000c00 | Resp[1]: 0x003a437f
[258933.125378] mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00400e00
[258933.125386] mmc0: sdhci: Host ctl2: 0x00000000
[258933.125395] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xded38208
[258933.125403] mmc0: sdhci: ============================================
[259336.328248] mmc0: Timeout waiting for hardware interrupt.
[259336.328260] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Help is appreciated.
