OK,I am back again
Now starting a fresh installation of Debian Stretch on a Raspberry Pi2 without any problem.
Now OpenHab2 (2.4.0-1) I did follow the procedure of https://www.openhab.org/download/
Install openHABian (Recommended)
Package Installation
As I was afraid : OpenHab2 can’t be reached doing http://:8080
Rebooting or restarting OpenHab doesn’t help.
Here is the first info:
pi@HA_Broker2:/etc/init.d $ /etc/init.d/openhab2 status
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2019-05-13 17:38:18 CEST; 28min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 21570 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 24591 (java)
CGroup: /system.slice/openhab2.service
└─24591 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dope…in
May 13 17:38:26 HA_Broker2 karaf[24591]: at org.eclipse.osgi.storage.Storage.save0(Storage.java:1041)
May 13 17:38:26 HA_Broker2 karaf[24591]: at org.eclipse.osgi.storage.Storage.save(Storage.java:1011)
May 13 17:38:26 HA_Broker2 karaf[24591]: at org.eclipse.osgi.internal.framework.StorageSaver$StorageSaverTask.run(StorageSaver.java:28)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Schedule….java:180)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThread….java:294)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
May 13 17:38:26 HA_Broker2 karaf[24591]: at java.lang.Thread.run(Thread.java:745)
Hint: Some lines were ellipsized, use -l to show in full.
Any Idea
Robert
