Dear folks.
I’m trying to make fresh install for openhab2.5 but having no luck.
I have the following scenario:
Have production openhab2.5 running on RPi3 with 120GB SSD, working like a dream.
I’m planning to migrate to openhab3, however I want to test this first before I make the move.
So, easy…I thought.
Let me created a second system, effectively I will perform a RESTORE on the 2nd system, used this as primary, then perform the migration to OPENHAB3.
If for any failure, I simply use my primary RPi3 system again.
So, for the backup RPI3, did I use “openhabian-pi-raspbian-201908050414-gitca0976f-crc6a66b5a1.img.xz” which I downloaded some time ago and installed via ETCHER onto 16Gb SDcard.
But the openhab portion does NOT installed.
After much debugging, have I located the issue down to the following unsuccessful script line found in the /boot/first-boot.bash:
“git clone -b master https://github.com/openhab/openhabian.git /opt/openhabian”
This provides error : “fatal: Remote branch master not found in upstream origin”
If I run : “git clone https://github.com/openhab/openhabian.git /opt/openhabian”,
then openhab installs but no “openhab2.service” is being created.
Ok, then trying the following:
After removing all efforts of openhab/git. I then tried using “apt-get install openahb2”, which completes.
I can startup the “openhab2.service”, website site comes up at x.x.x.x:8080 and then it shows busing building UI interface…after some hours…nothing happens.
It is as if this process gets stuck.
Anyone who could provide some guidance?
