Hi @Phelzier
Do we still need to enable Lightwave using the RFXtrx software to get mood switchs and wire free switchs working?
thanks in advance
James
Hi @Phelzier
thanks in advance
James
Hi @habnoob,
Yes, I used a windows machine to enable the Lightwave option. Initially I got the wireless switches up and running quite quickly, however I had issues with the mood controllers. Since then the bindings (and OpenHAB) have been updated, when I came back to try it again a few months ago the mood controllers worked just fine. Iâve now got the Lightwave switches integrated with my OpenHAB setup just as I wanted⊠and theyâre super reliable.
Hope that helps,
Regards, David.
Have you examples of your items and sitemaps for the lightwave kit
Hi @Chod,
Sure thingâŠ
My items look like this:
Switch MS13_16004850_switch âMS13 Switchâ { channel=ârfxcom:lighting5:abcdefgh:16004850_13:commandâ }
Number MS13_16004850_mood âMS13 Moodâ { channel=ârfxcom:lighting5:abcdefgh:16004850_13:moodâ }
I then use rules that get triggered when the mood number changes, based on the new value the rule then turns on/off various lights.
The Lightwave devices donât appear in my sitemap at all as they are just there for triggering different lighting setups.
I hope that helps,
Regards, David
Thanks @dwaterson
got it all working now - had to turn off ignore config
now to work out the rules âŠ
Kind regards
James
Could you show me your rules file? Iâm trying to get the slave switch to trigger another light when turned on and off but not sure about the rules file.
Hi @habnoob,
Glad you got it receiving the messages ok - I donât recall setting the ignore config but having checked mine itâs also enabled, so Iâm assuming I must have changed that.
My rules are not as straight forward as you expectâŠ
I have some âstandardâ on/off switches (ie not the mood controllers), I have a rule that looks for a status change to ON and a separate rule that looks for a status change to OFF. Each of these rules has a line that issues a postUpdate(NULL) to the Lightwave item⊠that means EVERY time one of the buttons is pushed the rule fires. The reason I do this is so that I can use each button to set certain lights on/off every time the button is pushed⊠that allows the room to be reset to a certain setup despite changes made through the app or other rules. In fact I have some virtual switches that in effect are only there to store the state of each scene⊠that allows me to âtoggleâ scenes on/off with a single button.
This was fiddly to setup but works really well⊠It means I can use a âdualâ Lightwave switch and each of the 4 buttons controls each of 4 different zones for on/off.
For my mood controllers the rules are far simpler, I look for a change to a specific value and then fire off commands to the relevant lights⊠I could simply my approach into a single rule that looks for a change and then has an IF statement for each of the values⊠I just chose this way as it was the easiest when first building a working example. Iâm not sure if one is more efficient than the other, but Iâve only two mood controllers so figured it wasnât too important.
I canât get to the rules right now, but Iâll try and grab an example later and post⊠itâs along the lines ofâŠ
rule âLightwave mood controller 1-1â
when Item lightwave_mood_1 changed to 1
sendCommand(someitem,ON)
rule âLightwave mood controller 1-2â
when Item lightwave_mood_1 changed to 2
sendCommand(someotheritem,ON)
rule âLightwave mood controller 1-0â
when Item lightwave_mood_1 changed to 0
sendCommand(someitem,OFF)
Hope that helps.
Regards, David
using the windows tool I have got the id/data of a Motion detector on lightwave protocol, to prove its working, added the usb configuration items to I think get the data connection
I have added the RFXCOM Binding with the RFXCOM Transceiver
Would I need the RFXCOM Lighting5 Actuator and or the RFXtrx433E USB 433.92Hz Transceiver as thats the hardware ?
not sure what parts are needed / comments appreciated
Hi @chod,
I added a âthingâ for âRFXCOM USB Transceiverâ⊠once that was correctly setup and working, the items automatically appeared in the inbox as they were discovered (eg for switches, I pressed all the buttons and the various items were added automatically).
Itâs been a while since I set this up, I recall having to setup the USB port manually in a config file. Iâm travelling at the moment so canât easily access my system but can check and let you know in a day or two if that would help?
Regards, David
Thanks David,
Hrm still no luck here though thanks for our examples.
Will post mine in the morning though they dont work, if you could take a look - I would be honored.
Kind regards
James
Good progress here, thanks to all posters of various pieces of information.
added RFXCOM USB Transceiver Binding, with settings for what you want to detect
I checked mine with windows RFXcommander? tool
Had to add bindings for items that I wanted to detect, Choose Thing type etc
Meanwhile the inbox was populating itself with a few local devices I did not know were 433mhz
Still no joy for me with this, i keep trying though still fails
Below are my items and rule, some output at the end
Zwave.items
Dimmer Bathroom "Bathroom [%d %%]" (Alights) [ "Lighting" ]
{channel="zwave:device:6f409fa7:node3:command",
channel="zwave:device:6f409fa7:node3:switch_dimmer1",
channel="zwave:device:6f409fa7:node3:sensor_power1",
channel="zwave:device:6f409fa7:node3:meter_kwh1",
channel="zwave:device:6f409fa7:node3:meter_watts1",
channel="zwave:device:6f409fa7:node3:alarm_general1"}
lwrf.items
Switch Slave_1 "Slave 1 [%d %%]"
{channel="rfxcom:lighting5:41f5363c_16060396_13:command"}
wirefree.rules
rule "Slave_1 On"
Item rfxcom_lighting5_41f5363c_16060396_13 changed to ON
Bathroom.sendCommand(ON)
rule "Slave_1 Off"
Item rfxcom_lighting5_41f5363c_16060396_13 changed to OFF
Bathroom.sendCommand(OFF)
log output
2018-05-25 19:36:39.182 [vent.ItemStateChangedEvent] - rfxcom_lighting5_41f5363c_16060396_13_command changed from OFF to ON
2018-05-25 19:36:39.187 [vent.ItemStateChangedEvent] - rfxcom_lighting5_41f5363c_16060396_13_contact changed from CLOSED to OPEN
2018-05-25 19:36:40.922 [vent.ItemStateChangedEvent] - rfxcom_lighting5_41f5363c_16060396_13_command changed from ON to OFF
2018-05-25 19:36:40.945 [vent.ItemStateChangedEvent] - rfxcom_lighting5_41f5363c_16060396_13_contact changed from OPEN to CLOSED
I will check my rules, but I am pretty sure you are ment to refer to your lightwave items the same way u do with your switch item
therefore
rule "wirefree.rules"
Item Slave_1 changed to ON
Thanks mate - im sure your right though I never see the switch called in the logs, only the lighting5 id so utterly confused!
Will try that now though
Still no joy
instead of âon offâ could i set a level as when i tell alexa to turn the device on or of it sends a dimmer value and not an âon offâ
just sendCommand(100) ?
Tried the above, didnt work ⊠argh!
the item ( the dimmer ) will need to be defined as a number in your items file to accept a value
Thanks, I think it is:
Dimmer Bathroom âBathroom [%d %%]â (Alights) [ âLightingâ ]
{channel=âzwave:device:6f409fa7:node3:commandâ,
channel=âzwave:device:6f409fa7:node3:switch_dimmer1â,
channel=âzwave:device:6f409fa7:node3:sensor_power1â,
channel=âzwave:device:6f409fa7:node3:meter_kwh1â,
channel=âzwave:device:6f409fa7:node3:meter_watts1â,
channel=âzwave:device:6f409fa7:node3:alarm_general1â}
I have not defined multiple items in one pass, i have always done one at a time (I am not saying its wrong, I just dont recall spotting it written by that method )
I have a wire free Lightwave mood controller here I just have never âseen itâ appear ?
What sequence did you use to spot it/pair/get serial to access its output
Hi @Chod - once I had the RFXcom up and running the wireless mood controllers just appeared in the inbox when I pressed the various buttons. Interestingly some switches appear as two separate items, Iâm guessing that the internal circuity is modular and report as separate devices.
I didnât need to pair it (although it had previously been paired to a Lightwave bridge, but Iâve not got that)⊠as I say, it just appeared once the radio was configured.
