Hi all,
although I’m reading in this forum for quite some time, I’m new to actively participate and I hope somebody is able to give me a hint or help me getting my openhab2 installation running properly.
Just a quick summary on what I’m working with:
- RaspBerryPi 2B+
- Raspbian Jessie lite
- openhab2, latest development release (via apt-get)
– package = standard
– binding = exec,max,ntp,systeminfo
– ui = basic,paper
– persistence = rrd4j
– transformation = map,regex,scale - 2x MAX!Cube with lots of components
I read that one of the objectives set for openhab2 is to encourage use of the UI to configure, however I hesitate to do so for some reasons. As I want to be able to recover/reinstall easily I prefer to have as much as possible preconfigured in configuration files. Therefore, I did not configure anything on the UI at the moment.
What I’ve done so far is to create files for all of my things, items, transforms, a.s.o… While I was struggeling with some issues on syntax in the very beginning I was able to arrange a configuration that is generally working and allowing me to have a look at all the values available from my MAX! components as well as some system information I added.
In a next step I was starting to adjust my sitemap to allow me to set temperature values for the thermostats. There I got stuck now, which is the reason for me asking for your support.
Allthough I see all the things being online in the PaperUI, I can see all the values (like ‘window is open’), my openhab2 lacks some functionality like setting temperatures and I get the following warning messages in my log files.
Some comments to be considered:
I understand that these warnings might be related to different issues.
I only copied one of each message although they show up multiple times (eg. for all my MAX! components).
Serialnumbers, IP-addresses, etc. are not the ‘real’ ones.
2016-12-14 21:11:44.002 [WARN ] [home.core.thing.binding.ThingFactory] - Could not create channel ‘run’ for thing type ‘exec:command:temp_raspberrypi’, because channel type ‘exec:running’ could not be found.
2016-12-14 21:11:44.986 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type REGEX
2016-12-14 21:11:45.013 [WARN ] [hab.binding.exec.handler.ExecHandler] - Couldn’t transform response because transformationService of type ‘REGEX’ is unavailable
2016-12-14 21:11:49.229 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key ntp:ntp:local in ManagedThingProvider, because it does not exists.
2016-12-14 21:11:50.028 [WARN ] [ome.core.thing.internal.ThingManager] - Attempt to initialize a handler twice for thing ‘max:thermostat:MEQ1234567:LEQ1234567’ at the same time will be ignored.
2016-12-14 21:11:50.567 [WARN ] [ome.core.thing.internal.ThingManager] - Attempt to initialize a handler twice for thing ‘max:wallthermostat:KEQ1234567:LEQ1234567’ at the same time will be ignored.
2016-12-14 21:11:50.604 [WARN ] [ome.core.thing.internal.ThingManager] - Attempt to initialize a handler twice for thing ‘max:shuttercontact:KEQ1234567:LEQ1234567’ at the same time will be ignored.
2016-12-14 21:12:20.086 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key max:bridge:MEQ1234567 in ManagedThingProvider, because it does not exists.
2016-12-14 21:12:20.090 [WARN ] [.core.thing.binding.BaseThingHandler] - Error while applying configuration changes: ‘IllegalStateException: Could not update thing max:bridge:MEQ1234567. Most likely because it is read-only.’ - reverting configuration changes on thing ‘max:bridge:MEQ1234567’.
2016-12-14 21:12:20.127 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key max:bridge:MEQ1234567 in ManagedThingProvider, because it does not exists.
2016-12-14 21:12:20.129 [WARN ] [.core.thing.binding.BaseThingHandler] - Error while applying configuration changes: ‘IllegalStateException: Could not update thing max:bridge:MEQ1234567. Most likely because it is read-only.’ - reverting configuration changes on thing ‘max:bridge:MEQ1234567’.
2016-12-14 21:12:20.134 [INFO ] [nternal.handler.MaxCubeBridgeHandler] - Error while handling message block: ‘M:00,01,…’ from MAX! Cube lan gateway: 192.168.xxx.xx:java.lang.IllegalStateException: Could not update thing max:bridge:MEQ1234567. Most likely because it is read-only.
at org.eclipse.smarthome.core.thing.internal.ThingManager$1.thingUpdated(ThingManager.java:224)[103:org.eclipse.smarthome.core.thing:0.9.0.201612091054]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateConfiguration(BaseThingHandler.java:478)[103:org.eclipse.smarthome.core.thing:0.9.0.201612091054]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.setProperties(MaxCubeBridgeHandler.java:727)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.processMessage(MaxCubeBridgeHandler.java:592)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.readliness(MaxCubeBridgeHandler.java:536)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.sendCubeCommand(MaxCubeBridgeHandler.java:482)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.refreshData(MaxCubeBridgeHandler.java:364)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.access$0(MaxCubeBridgeHandler.java:361)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler$1.run(MaxCubeBridgeHandler.java:159)[175:org.openhab.binding.max:2.0.0.201612120809]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
2016-12-14 21:12:20.636 [WARN ] [.core.thing.binding.BaseThingHandler] - Error while applying configuration changes: ‘IllegalStateException: Could not update thing max:shuttercontact:KEQ1234567:LEQ1234567. Most likely because it is read-only.’ - reverting configuration changes on thing ‘max:shuttercontact:KEQ1234567:LEQ1234567’.
2016-12-14 21:12:20.848 [INFO ] [nternal.handler.MaxCubeBridgeHandler] - Error while handling message block: ‘F:ntp.homematic.com,ntp.homematic.com’ from MAX! Cube lan gateway: 192.168.xxx.xx:java.lang.IllegalStateException: Could not update thing max:bridge:MEQ1234567. Most likely because it is read-only.
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.setProperties(MaxCubeBridgeHandler.java:743)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.processMessage(MaxCubeBridgeHandler.java:671)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.sendCommands(MaxCubeBridgeHandler.java:347)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler.access$1(MaxCubeBridgeHandler.java:334)[175:org.openhab.binding.max:2.0.0.201612120809]
at org.openhab.binding.max.internal.handler.MaxCubeBridgeHandler$2.run(MaxCubeBridgeHandler.java:167)[175:org.openhab.binding.max:2.0.0.201612120809]
As soon as I change the temperature in basicUI (using ‘setpoint’), I get the following log-message:
2016-12-14 22:13:39.571 [INFO ] [ome.core.thing.internal.ThingManager] - Not delegating update '22.5' for item 'Thermostat_UG_Wohnzimmer_SET' to handler for channel 'max:thermostat:KEQ1234567:KEQ1234567:set_temp', because handler is not initialized (thing must be in status UNKNOWN, ONLINE or OFFLINE).
Which I don’t understand the reason for, as the thermostat seems to be successfully going online before that timestamp:
2016-12-14 21:11:42.997 [ItemChannelLinkAddedEvent ] - Link 'Thermostat_UG_Wohnzimmer_SET-max:thermostat:KEQ1234567:KEQ1234567:set_temp' has been added.
2016-12-14 21:11:47.790 [ThingAddedEvent ] - Thing 'max:thermostat:KEQ1234567:KEQ1234567' has been added.
2016-12-14 21:11:47.956 [hingStatusInfoChangedEvent] - 'max:thermostat:KEQ1234567:KEQ1234567' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2016-12-14 21:11:49.760 [hingStatusInfoChangedEvent] - 'max:thermostat:KEQ1234567:KEQ1234567' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2016-12-14 21:11:50.561 [ThingUpdatedEvent ] - Thing 'max:thermostat:KEQ1234567:KEQ1234567' has been updated.
2016-12-14 21:12:21.473 [hingStatusInfoChangedEvent] - 'max:thermostat:KEQ1234567:KEQ1234567' changed from INITIALIZING to ONLINE
=> My focus is on getting my MAX! components running.
However I would greatly appreciate if someone could help me separating if multiple issues cause the logs seen above.
If information is missing, just let me know! I’m happy to add as necessary…
PS: I’ve seen that there was another thread related to one of the warnings above: ‘Frequent warnings in log if max things are configured via textual files’. Unfortunately this thread did not provide a solution other than configuring via UI instead of files.
Best regards
Karsten
