Thank you for reading my message! I’m trying to install the Modbus add-on on my old Openhab installation, I know that I need to upgrade but at the moment I don’t have the time to do that and I would like to add this binding.
Thank you in advance!
Openhab 2.4.0.M5 Milestone Build
-From the UI, I got the following message: Error downloading mvn:org.openhab.binding/org.openhab.binding.modbus /2.4.0.M5
-From the CLI I did try the following with the 2.4 version and 2.5 but the same result.
Thanks you for the reply. I figured out that I can no longer install it from the GUI. However, if I’m not mistaking the org.openhab.binding.modbus-2.5.0 should work on this instance of Openhab?
And I see that that user is installing a 1.x binding. This one is to old for me to use.
Fully agree! And indeed I’m running on an old version but I still hope to fo find someone who can tell me what extra I need to install in order to sole the errors.
