I´m using OpenHab2 on a Raspberry Pi 3 running Raspbian to control currently 2 Sonoff Basics with Tasmota flashed. They used to work perfectly fine until today, when I tried to add something new. The lights won´t turn off/on anymore. So I undid all my changes, but the problem remained. Figuring that would be the easiest way to go I reinstalled openhab and reconfigured the switches following this tutorial: https://github.com/arendst/Sonoff-Tasmota/wiki/openHAB
But it still doesn´t work and I have currently no clue whatsoever why. I guess I´m just missing something and hoping that somebody can point it out to me.
JavaScript, JSONPath and Map Transformation are installed. MQTT Binding and Action are also installed.
The switches are controllable, I can turn the lights on/off by sending the MQTT Message directly so they are properly conntected to the mosquitto server running on the raspberry. Thanks in advance!
They aren´t controllable via OpenHab, but if I send the command via e.g. mqttFX they work. So they are working properly, but I failed to configure OpenHab correctly and I don´t know where my mistake is.
you could just change to that thread also, and please provide the entries in events.log (there should be some indication for the broker connection and some information on the changing switches)
As suggested by @PawelGrzembka I commented the retain part out (and corrected it to a boolean value, but I already did that beforehand, just forgot to update my post).
Thanks @binderth for pointing me towards the event log. I should have started by looking into that. I had a few errors/warnings there:
15:07:07.606 [ERROR] [.ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Livingroom_Light' for widget org.eclipse.smarthome.model.sitemap.Switch
The “R” of LivingRoom_Light was supposed be a a capital one like in the items file.
Also this warning, but I guess it didn´t cause any problems (yet) 15:06:06.808 [WARN ] [.sitemap.internal.SitemapProviderImpl] - Filename myHome.sitemap does not match the name mySmarthome of the sitemap - please fix this as you might see unexpected behavior otherwise.
Now everything seems to work fine again. Thanks guys!
This time I´ll make a backup before changing anything else even though there is not much to actually make a backup of
