with sudo apt-get clean / autoclean / autoremove and cleaning up some large back-up files
I know have:
pi@raspberrypi-1:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.2G 5.1G 1.8G 75% /
devtmpfs 363M 0 363M 0% /dev
tmpfs 367M 68K 367M 1% /dev/shm
tmpfs 367M 5.4M 362M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 367M 0 367M 0% /sys/fs/cgroup
/dev/mmcblk0p1 63M 22M 42M 35% /boot
tmpfs 74M 0 74M 0% /run/user/1000
Now restart openhab2.service gives the following status:
pi@raspberrypi-1:~ $ sudo systemctl status openhab2.service -l
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: deactivating (stop) (Result: exit-code) since Wed 2017-10-18 20:51:37 CEST; 795ms ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 9639 ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE (code=exited, status=254)
Main PID: 9639 (code=exited, status=254); : 9774 (karaf)
CGroup: /system.slice/openhab2.service
└─control
├─9774 /bin/sh /usr/share/openhab2/runtime/bin/karaf stop
├─9867 /bin/sh /usr/share/openhab2/runtime/bin/karaf stop
├─9868 /usr/bin/java -version
├─9869 grep -E "([0-9].[0-9]\..*[0-9]).*"
├─9870 awk {print substr($3,2,length($3)-2)}
├─9871 awk {print substr($1, 3, 3)}
└─9872 sed -e s;\.;;g
Oct 18 20:51:35 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: null
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: java.lang.NumberFormatException: null
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:227)
Oct 18 20:51:37 raspberrypi-1 karaf[9639]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:51:37 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
And the output of journalctl is
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: java.lang.NumberFormatException: null
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:53:11 raspberrypi-1 karaf[12625]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:53:11 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:53:12 raspberrypi-1 karaf[12755]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:53:12 raspberrypi-1 karaf[12755]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:12 raspberrypi-1 karaf[12755]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:12 raspberrypi-1 karaf[12755]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:12 raspberrypi-1 karaf[12755]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:53:12 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:53:12 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:53:17 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:53:17 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:53:17 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:53:17 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: null
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: java.lang.NumberFormatException: null
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:53:19 raspberrypi-1 karaf[12894]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:53:19 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:53:21 raspberrypi-1 karaf[13025]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:53:21 raspberrypi-1 karaf[13025]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:21 raspberrypi-1 karaf[13025]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:21 raspberrypi-1 karaf[13025]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:21 raspberrypi-1 karaf[13025]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:53:21 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:53:21 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:53:26 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:53:26 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:53:26 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:53:26 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: null
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: java.lang.NumberFormatException: null
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:53:28 raspberrypi-1 karaf[13162]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:53:28 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:53:29 raspberrypi-1 karaf[13293]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:53:29 raspberrypi-1 karaf[13293]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:29 raspberrypi-1 karaf[13293]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:29 raspberrypi-1 karaf[13293]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:29 raspberrypi-1 karaf[13293]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:53:29 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:53:29 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:53:34 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:53:34 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:53:34 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:53:34 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: null
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: java.lang.NumberFormatException: null
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:53:36 raspberrypi-1 karaf[13426]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:53:36 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:53:38 raspberrypi-1 karaf[13557]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:53:38 raspberrypi-1 karaf[13557]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:38 raspberrypi-1 karaf[13557]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:38 raspberrypi-1 karaf[13557]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:38 raspberrypi-1 karaf[13557]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:53:38 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:53:38 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:53:43 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:53:43 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:53:43 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:53:43 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: null
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: java.lang.NumberFormatException: null
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:53:45 raspberrypi-1 karaf[13693]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:53:45 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:53:46 raspberrypi-1 karaf[13827]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:53:46 raspberrypi-1 karaf[13827]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:46 raspberrypi-1 karaf[13827]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:46 raspberrypi-1 karaf[13827]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:46 raspberrypi-1 karaf[13827]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:53:46 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:53:46 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:53:51 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:53:51 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:53:51 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:53:51 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: null
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: java.lang.NumberFormatException: null
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:53:53 raspberrypi-1 karaf[13967]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:53:53 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:53:55 raspberrypi-1 karaf[14104]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:53:55 raspberrypi-1 karaf[14104]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:53:55 raspberrypi-1 karaf[14104]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:53:55 raspberrypi-1 karaf[14104]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:53:55 raspberrypi-1 karaf[14104]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:53:55 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:53:55 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:54:00 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:54:00 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:54:00 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:54:00 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: null
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: java.lang.NumberFormatException: null
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:54:02 raspberrypi-1 karaf[14240]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:54:02 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:54:03 raspberrypi-1 karaf[14371]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:54:03 raspberrypi-1 karaf[14371]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:03 raspberrypi-1 karaf[14371]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:03 raspberrypi-1 karaf[14371]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:03 raspberrypi-1 karaf[14371]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:54:03 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:54:03 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:54:08 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:54:08 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:54:08 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:54:08 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: null
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: java.lang.NumberFormatException: null
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:54:10 raspberrypi-1 karaf[14509]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:54:10 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:54:12 raspberrypi-1 karaf[14641]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:54:12 raspberrypi-1 karaf[14641]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:12 raspberrypi-1 karaf[14641]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:12 raspberrypi-1 karaf[14641]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:12 raspberrypi-1 karaf[14641]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:54:12 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:54:12 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:54:17 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:54:17 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:54:17 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:54:17 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: null
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: java.lang.NumberFormatException: null
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:54:19 raspberrypi-1 karaf[14777]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:54:19 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:54:20 raspberrypi-1 karaf[14909]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:54:20 raspberrypi-1 karaf[14909]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:20 raspberrypi-1 karaf[14909]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:20 raspberrypi-1 karaf[14909]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:20 raspberrypi-1 karaf[14909]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:54:20 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:54:20 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:54:25 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:54:25 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:54:25 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:54:25 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: null
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: java.lang.NumberFormatException: null
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:54:28 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:54:30 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:54:30 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:54:35 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:54:35 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:54:35 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:54:35 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: null
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: java.lang.NumberFormatException: null
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:54:37 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: Exception in thread "main" java.lang.NumberFormatExce
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: at org.apache.karaf.main.Stop.main(Stop.java:44)
Oct 18 20:54:39 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited s
Oct 18 20:54:39 raspberrypi-1 systemd[1]: Unit openhab2.service entered failed state.
Oct 18 20:54:44 raspberrypi-1 systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 18 20:54:44 raspberrypi-1 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Oct 18 20:54:44 raspberrypi-1 systemd[1]: Starting openHAB 2 - empowering the smart home...
Oct 18 20:54:44 raspberrypi-1 systemd[1]: Started openHAB 2 - empowering the smart home.
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: null
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: Error occurred shutting down framework: java.lang.Num
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: java.lang.NumberFormatException: null
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at java.lang.Integer.parseInt(Integer.java:542)
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at java.lang.Integer.parseInt(Integer.java:615)
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at org.apache.karaf.main.ConfigProperties.<init>(Conf
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at org.apache.karaf.main.Main.updateInstancePidAfterS
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at org.apache.karaf.main.Main.main(Main.java:192)
Oct 18 20:54:46 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, sta
lines 1001-1051/1051 (END)
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Oct 18 20:54:28 raspberrypi-1 karaf[15046]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:227)
Oct 18 20:54:28 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: Exception in thread "main" java.lang.NumberFormatException: null
Oct 18 20:54:30 raspberrypi-1 karaf[15177]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Oct 18 20:54:30 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited status=1
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Oct 18 20:54:37 raspberrypi-1 karaf[15325]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:227)
Oct 18 20:54:37 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: Exception in thread "main" java.lang.NumberFormatException: null
Oct 18 20:54:39 raspberrypi-1 karaf[15460]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Oct 18 20:54:39 raspberrypi-1 systemd[1]: openhab2.service: control process exited, code=exited status=1
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:214)
Oct 18 20:54:46 raspberrypi-1 karaf[15596]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:227)
Oct 18 20:54:46 raspberrypi-1 systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Unfortunately I can’t really make sence of it
