Openhab2 not starting (after update)
Hello guys,
i updated to the newest snapshot version and after this update i cant see my webinterface. Server is not reachable.
When look at my linux VM, i can see the cpu usage is jumping from 22 to 26 and back.
sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
   Active: deactivating (stop) (Result: exit-code) since Fr 2017-07-21 00:40:05               CEST; 110ms ago
     Docs: http://docs.openhab.org
           https://community.openhab.org
  Process: 28566 ExecStart=/usr/share/openhab2/start.sh server (code=exited, sta              tus=254)
 Main PID: 28566 (code=exited, status=254);         : 28736 (stop)
   CGroup: /system.slice/openhab2.service
           └─control
             ├─28736 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28753 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28754 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28755 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28764 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28767 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28770 /bin/sh /usr/share/openhab2/runtime/bin/stop
             ├─28795 n/a
             └─28796 sed -e s#//#/#g -e s#/./#/#g -e s#/[^/]*/../#/#g
Jul 21 00:40:04 debianohab start.sh[28566]: /usr/share/openhab2/runtime/bin/....
Jul 21 00:40:05 debianohab start.sh[28566]: null
Jul 21 00:40:05 debianohab start.sh[28566]: Error occurred shutting down fra...l
Jul 21 00:40:05 debianohab start.sh[28566]: java.lang.NumberFormatException:...l
Jul 21 00:40:05 debianohab start.sh[28566]: at java.lang.Integer.parseInt(In...)
Jul 21 00:40:05 debianohab start.sh[28566]: at org.apache.karaf.main.ConfigP...)
Jul 21 00:40:05 debianohab start.sh[28566]: at org.apache.karaf.main.Main.up...)
Jul 21 00:40:05 debianohab start.sh[28566]: at org.apache.karaf.main.Main.ma...)
Jul 21 00:40:05 debianohab systemd[1]: openhab2.service: main process exite.../a
Hint: Some lines were ellipsized, use -l to show in full.
openhab log seems to be clear.
stopping and starting the service again, changed nothing
Any ideas what to do?
Edit:
   Active: active (running) since Fr 2017-07-21 13:02:51 CEST; 949ms ago
  Process: 16924 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=1/FAILURE)
 Main PID: 17102 (karaf)
           ├─17102 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
           └─17256 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userd...
Jul 21 13:02:51 debianohab systemd[1]: Started openHAB 2 - empowering the smart home.
Jul 21 13:02:51 debianohab start.sh[17102]: Launching the openHAB runtime...
Jul 21 13:02:52 debianohab start.sh[17102]: /usr/share/openhab2/runtime/bin/karaf: Zeile 355: [: : Ganzzahliger Ausdruck erwartet.
root@debianohab:/home/m3ta# sudo systemctl status openhab2.service
   Active: deactivating (stop) (Result: exit-code) since Fr 2017-07-21 13:02:52 CEST; 392ms ago
  Process: 17102 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=254)
 Main PID: 17102 (code=exited, status=254);         : 17274 (karaf)
           └─control
             ├─17274 /bin/bash /usr/share/openhab2/runtime/bin/karaf stop
             ├─17375 /bin/bash /usr/share/openhab2/runtime/bin/karaf stop
             ├─17376 /usr/lib/jvm/java-8-oracle/jre/bin/java -version
             ├─17377 grep -E "([0-9].[0-9]\..*[0-9]).*"
             ├─17378 awk {print substr($3,2,length($3)-2)}
             ├─17379 awk {print substr($1, 3, 3)}
             └─17380 sed -e s;\.;;g
Jul 21 13:02:52 debianohab start.sh[17102]: null
Jul 21 13:02:52 debianohab start.sh[17102]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Jul 21 13:02:52 debianohab start.sh[17102]: java.lang.NumberFormatException: null
Jul 21 13:02:52 debianohab start.sh[17102]: at java.lang.Integer.parseInt(Integer.java:542)
Jul 21 13:02:52 debianohab start.sh[17102]: at java.lang.Integer.parseInt(Integer.java:615)
Jul 21 13:02:52 debianohab start.sh[17102]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:208)
Jul 21 13:02:52 debianohab start.sh[17102]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:226)
Jul 21 13:02:52 debianohab start.sh[17102]: at org.apache.karaf.main.Main.main(Main.java:191)
Jul 21 13:02:52 debianohab systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Jul 21 13:02:53 debianohab stop[17274]: stop: Ignoring predefined value for KARAF_HOME
Edit2: By uninstalling an reinstalling openhab2+ addons, i get the following output:
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; disabled)
   Active: active (running) since Fr 2017-07-21 18:41:01 CEST; 955ms ago
  Process: 21561 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, sta                       tus=1/FAILURE)
 Main PID: 21739 (karaf)
           ├─21739 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
           ├─21875 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
           ├─21876 /usr/bin/java -version
           ├─21877 grep -E "([0-9].[0-9]\..*[0-9]).*"
           ├─21878 awk {print substr($3,2,length($3)-2)}
           ├─21879 awk {print substr($1, 3, 3)}
           └─21880 sed -e s;\.;;g
Jul 21 18:41:01 debianohab systemd[1]: Started openHAB 2 - empowering the s...e.
Jul 21 18:41:01 debianohab start.sh[21739]: Launching the openHAB runtime...
Jul 21 18:41:02 debianohab start.sh[21739]: mkdir: das Verzeichnis „/var/lib…bar
Best regards :slight_smile:
