Java Runtime Environment: _which java platform is used and what version_jdk 8
openHAB version: 2.4
default .qpkg install of 2.4 openhab2
I cannot find the .things/.items etc config files…anywhere.
I have tried to search using: env, printenv, find, and ls. none have found the config files.
Yes I am new to both Linux and openhab2 so be gentle please.
I have manual created things, items, in the paper ui so I know they are out there.
I have created both things and items both by discovery and by manually creating them…so…
I did not install the demo and I do have working things and items.
The /share/CACHEDEV1_DATA/.qpkg/OpenHab/conf folders do exist but the only files in any of them are the readme files. no .things or .items in the things and items folders.
Creating Things and Items in PaperUI does not create xxx.things or xxx.items files. Those go into a magical JSONDB store.
These are alternate means to manage Things and Items, not two parts of the same process. The end results are the same - openHAB objects. But the sources are different.
See, I told you I was green on this. So the paper ui does not generate a .things file…hmm.
Would I be correct in assuming that there is a very well documented way to get the config info from the things I have already discovered and created into the conf folders then? And then the conf folders supersede the “JSONDB store” config info that exists out there?
