openHAB2.service in failed state
Hi guys,
Just getting started in openHAB, but I’ve run into a block before I could get far. I’m installing openHAB on a spin of Debian Jessie, and when I try to /etc/init.d openhab2 start, the service always enters a failed state. I’ve attached a picture of the init.d openHAB2 status.
what is the output of java -version?
Try using Oracle or Zulu JVM
OH2 release used? (apt-get installation?)
Release is latest stable, but running java reminded me I hadn’t put it on here yet. DOH! I’ll install it and get back with you. I’d have thought it would install java jvm as a prereq in apt.
that’s not a bad idea actually :slight_smile:
btw: http://docs.openhab.org/installation/index.html#prerequisites
OK, so I’ve got OpenJDK on the box now, but here’s the new output of status.
I’ve had some problems in the past with OpenJDK on Jessie… can you try either Oracle or Zulu and see if things improve?
Try to execute: /usr/share/openhab2/start_debug.sh to see if you get more useful info
Also, if you can, post the contents of /usr/lib/systemd/system/openhab2.service
The rest seems unnecessary. I wget’d the .deb for Zulu OpenJDK, and installed that. Now the runtime is starting, We’ll see how it goes…
http://imgur.com/5sipjTs
Also, on a separate note, some of my posts that I had images linked in were hidden by “community members” as spam. Am I doing something wrong?
No clue why this happened… :frowning: :confused:
Maybe the forum software (discourse) has some kind of auto protection (rate limit) for new users? (i don’t know…)
