OPENHAB2 service is unable to start
  • Platform information:
    • Hardware: Raspberry Pi 3 * OS: Raspbian Stretch
    • Java Runtime Environment: Arm 32bit JDK on Linux (for Armv8/v7/v6 Hard Float ABI)
  • openHAB version: 2.4.0 stable
  • Issue of the topic: unable to start openHab service.
after installing (*steps done are below) openHab, everthing was ok without any error, we start the openHab service, it show Ok, we check for the status, it shows:
pi@RasPi:~ $ **sudo /etc/init.d/openhab2 status**
● openhab2.service - openHAB 2 - empowering the smart home
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; disabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Sat 2019-01-05 09:57:35 GMT; 4s ago
     Docs: https://www.openhab.org/docs/
           https://community.openhab.org
  Process: 3098 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
  Process: 3082 ExecStart=/usr/share/openhab2/runtime/bin/karaf $OPENHAB_STARTMODE (code=exited, status=1/FAILURE)
 Main PID: 3082 (code=exited, status=1/FAILURE)
Jan 05 09:57:35 RasPi systemd[1]: openhab2.service: Unit entered failed state.
Jan 05 09:57:35 RasPi systemd[1]: openhab2.service: Failed with result 'exit-code'.
we continue to check for the log however the log file wasn’t in the defined location.
pi@RasPi:~ $ **sudo openhab-cli showlogs**
tail: cannot open '/var/log/openhab2/*.log' for reading: No such file or directory
tail: no files remaining
pi@RasPi:~ $
when we use the command to Start again, it shows:
pi@RasPi:~ $ **sudo openhab-cli start**
A systemd service configuration exists...
Use 'sudo /bin/systemctl start openhab2.service' to start an openHAB service
Launching an instance in this terminal..
Launching the openHAB runtime...
**java command not found**
so the java was installed before
I also check the line:
pi@RasPi:~ $ java -version
openjdk version "1.8.0_192"
OpenJDK Runtime Environment (Zulu 8.33.0.134-linux_aarch32hf) (build 1.8.0_192-b134)
OpenJDK Client VM (Zulu 8.33.0.134-linux_aarch32hf) (build 25.192-b134, mixed mode, Evaluation)
pi@RasPi:~ $
could you please help to on this issue :-s
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
is there anybody help ???
can anyone help me??
Did you install manually or use apt-get/openhabian image?
Dear H102
Thank you for your support. I did manually install the OpenHab on clean Raspbian Stretch lite OS
however I got failed while starting the Openhabservice.
I would recommend installing OH via apt-get or use the openhabian image.
Hey,
can you please manually run /usr/share/openhab2/runtime/bin/karaf on the console and tell us the output?
I had the same symptoms when Java/Zulu hasn’t been installed, but that doesn’t seem to be the case here.
Edit: Forget about my first writing: openhab-cli start above says that java command can’t be found. So you would have to investigate this.
But yeah, as @H102 said: OpenHABian would be the easier way. Create a microSD card with the image, connect RPI to the internet, and in about 15 minutes you have your system up and running.
Dear Stefan
Thanks for your support,
i’ve that backup plan. however i wanted to dig a bit deeper on this to see which component needed to install OpenHab.
@nhatthanh here is a post that may help as the java command is not found.
thank you H102
as this image is Rasbian Stretch Lite Image so i believe i didn’t include the java (zulu) by default.
so if i install zulu then obviously it must be the default one.
in fact i’ve tried this command and the command returned: there is no other java running on this OS.
OH runs with user openhab and I see above that you have installed java but have you set the correct environment variables to allow openhab access to java?
