Another way to get information about the installed devices chanels and parmeters is to install the XML-API extension on the CCU-2. Via the XML-API you can get a list of all devices together with the necessary information.
Is the terminology for the items derinition the same in openHAB2?
I can control my item via the Control-tab of the Paper UI. Using the item-definition of openHAB 1.7 and seting it up on the sidemap gives me a switch on the Basic UI but no reaction on the item.
Here the Log:
2016-06-20 23:18:29.998 [INFO ] [marthome.event.ItemStateChangedEvent] - homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL changed from 99 to 0
2016-06-20 23:18:33.259 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL' received command ON
2016-06-20 23:18:33.273 [INFO ] [marthome.event.ItemStateChangedEvent] - homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL changed from 0 to 100
2016-06-20 23:18:36.571 [INFO ] [marthome.event.ItemStateChangedEvent] - homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL changed from 100 to 99
2016-06-20 23:18:36.598 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL' received command 90
2016-06-20 23:18:36.608 [INFO ] [marthome.event.ItemStateChangedEvent] - homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL changed from 99 to 90
2016-06-20 23:18:36.870 [INFO ] [marthome.event.ItemStateChangedEvent] - homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL changed from 90 to 93
2016-06-20 23:18:36.896 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL' received command 86
2016-06-20 23:18:36.907 [INFO ] [marthome.event.ItemStateChangedEvent] - homematic_HM_LC_Dim1T_FM_8f146247_LEQ1234567_1_LEVEL changed from 93 to 86
2016-06-20 23:18:43.651 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_Esstisch' received command 0
2016-06-20 23:18:43.669 [INFO ] [marthome.event.ItemStateChangedEvent] - Light_Esstisch changed from 36 to 0
2016-06-20 23:18:43.846 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_Esstisch' received command 0
2016-06-20 23:18:47.531 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_Esstisch' received command 100
2016-06-20 23:18:47.551 [INFO ] [marthome.event.ItemStateChangedEvent] - Light_Esstisch changed from 0 to 100
2016-06-20 23:18:47.733 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_Esstisch' received command 100
The binding seems to have some problems to get the correct names from the CCU and sometimes it gets the correct names but then forgets them.
That’s why I have created a .items file by hand with all my Homemtatic components. Unfortunately you will have to use the full name for the channel reference (like this one Number tempBalkon "Temperatur [%.1f °C]" <temperature> {channel="homematic:HM-WDS10-TH-O:40efc356:MEQ0202430:1#TEMPERATURE"}).
