Hello Team,
I’m pretty new to Openhab. I’m trying to implement the Wunderground weather. I have followed the above experts instructions to implement the webview. The issue is that I’m receiving pure html file like below instead of the parsed html:
I did a manual installation and here is my file structure:
Here is my Sitemap:
sitemap _default label="My Home"
Frame label="Today" {
Text item=Temperature_F icon="temperature" valuecolor=[>77="orange",>60="green",>40="aqua]",<=40="blue"]
Text item=Humidity icon="p_humidity"
Text item=Visibility_Mph icon="temperature"
Text item=Pressure_Inches icon="temperature"
Text item=Pressure_Trend icon="temperature"
Text item=Condition icon="p_clear_sky"
Text item=ObservationTime icon="p_clear_sky"
Webview url="http://pi:8080/weather?locationId=homeEdmond&layout=weather&iconset=colorful" height=7
Here is my weather.cfg file (I have replaced my info with xxxx):
apikey.Wunderground=xxxx
location.homeEdmond.language=en
location.homeEdmond.latitude=xxxx
location.homeEdmond.longitude=xxxx
location.homeEdmond.name=xxxx
location.homeEdmond.provider=Wunderground
location.homeEdmond.updateInterval=1
Here is my weather.html file:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-type" CONTENT="text/html; charset=utf-8">
<link rel="stylesheet" type="text/css" href="static/weather-data/layouts/example.css" />
<script type="text/javascript" src="static/weather-data/layouts/example.js"></script>
</head>
<body id="weather-body" onload="formatIframe()">
<div id="weather-location-name">${config:name}, ${weather:condition.observationTime(%1$td.%1$tm.%1$tY %1$tH:%1$tM)}</div>
<table id="weather-table">
<tr>
<td rowspan="2"><img id="weather-icon" src="static/weather-data/images/${param:iconset}/${weather:condition.commonId}.png" /></td>
<td id="weather-temp">${weather:temperature.current}</td>
<td id="weather-temp-sign">°C</td>
</tr>
<tr>
<td colspan="2">
<table id="weather-table-details">
<tr>
<td>Luftfeuchte:</td>
<td>${weather:atmosphere.humidity} %</td>
</tr>
<tr>
<td>Luftdruck:</td>
<td>${weather:atmosphere.pressure} mb</td>
</tr>
<tr>
<td>Wind:</td>
<td>${weather:wind.speed} km/h aus ${weather:wind.direction}</td>
</tr>
</table>
</td>
</tr>
</table>
<table id="weather-forecast-table">
<tr>
<td>Today</td>
<td>${forecast(0):temperature.min(%.0f)}</td>
<td>${forecast(0):temperature.max(%.0f)}</td>
</tr>
<tr>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(0):condition.commonId}.png" /></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(1):condition.commonId}.png" /></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(2):condition.commonId}.png" /></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(3):condition.commonId}.png" /></td>
<td><img src="static/weather-data/images/${param:iconset}/${forecast(4):condition.commonId}.png" /></td>
</tr>
<tr>
<td class="temp-max">${forecast(0):temperature.max(%.0f)}</td>
<td class="temp-max">${forecast(1):temperature.max(%.0f)}</td>
<td class="temp-max">${forecast(2):temperature.max(%.0f)}</td>
<td class="temp-max">${forecast(3):temperature.max(%.0f)}</td>
<td class="temp-max">${forecast(4):temperature.max(%.0f)}</td>
</tr>
<tr>
<td class="temp-min">${forecast(0):temperature.min(%.0f)}</td>
<td class="temp-min">${forecast(1):temperature.min(%.0f)}</td>
<td class="temp-min">${forecast(2):temperature.min(%.0f)}</td>
<td class="temp-min">${forecast(3):temperature.min(%.0f)}</td>
<td class="temp-min">${forecast(4):temperature.min(%.0f)}</td>
</tr>
</table>
</body>
Here is my default.items file:
// atmosphere
Number Humidity "Humidity [%d %%]" {weather="locationId=homeEdmond, type=atmosphere, property=humidity"}
Number Visibility "Visibility [%.2f km]" {weather="locationId=homeEdmond, type=atmosphere, property=visibility"}
Number Visibility_Mph "Visibility [%.2f mi]" {weather="locationId=homeEdmond, type=atmosphere, property=visibility, unit=mph"}
Number Pressure "Pressure [%.2f mb]" {weather="locationId=homeEdmond, type=atmosphere, property=pressure"}
Number Pressure_Inches "Pressure [%.2f in]" {weather="locationId=homeEdmond, type=atmosphere, property=pressure, unit=inches"}
String Pressure_Trend "Pressure Trend [%s]" {weather="locationId=homeEdmond, type=atmosphere, property=pressureTrend"}
//Number Ozone "Ozone [%d ppm]" {weather="locationId=homeEdmond, type=atmosphere, property=ozone"}
//Number UV_Index "UV Index" {weather="locationId=homeEdmond, type=atmosphere, property=uvIndex, scale=0"}
// clouds
//Number Clouds "Clouds [%.0f %%]" {weather="locationId=home, type=clouds, property=percent"}
// condition
String Condition "Condition [%s]" {weather="locationId=homeEdmond, type=condition, property=text"}
String Condition_ID "Condition id [%s]" {weather="locationId=homeEdmond, type=condition, property=id"}
DateTime ObservationTime "Observation time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {weather="locationId=homeEdmond, type=condition, property=observationTime"}
DateTime LastUpdate "Last update [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {weather="locationId=homeEdmond, type=condition, property=lastUpdate"}
String CommonId "Common id [%s]" {weather="locationId=homeEdmond, type=condition, property=commonId"}
// precipitation
Number Rain "Rain [%.2f mm/h]" {weather="locationId=homeEdmond, type=precipitation, property=rain"}
Number Rain_Inches "Rain [%.2f in/h]" {weather="locationId=homeEdmond, type=precipitation, property=rain, unit=inches"}
Number Snow "Snow [%.2f mm/h]" {weather="locationId=homeEdmond, type=precipitation, property=snow"}
Number Snow_Inches "Snow [%.2f in/h]" {weather="locationId=homeEdmond, type=precipitation, property=snow, unit=inches"}
Number Precip_Probability "Precip probability [%d %%]" {weather="locationId=homeEdmond, type=precipitation, property=probability"}
// new total property in 1.8, only Wunderground
Number Precip_Total "Precip total [%d mm]" {weather="locationId=homeEdmond, type=precipitation, property=total"}
Number Precip_Total_Inches "Precip total [%d in]" {weather="locationId=homeEdmond, type=precipitation, property=total, unit=inches"}
// temperature
Number Temperature "Temperature [%.2f °C]" {weather="locationId=homeEdmond, type=temperature, property=current"}
Number Temperature_F "Temperature [%.2f F]" {weather="locationId=homeEdmond, type=temperature, property=current, unit=fahrenheit"}
Number Temp_Feel "Temperature feel [%.2f °C]" {weather="locationId=homeEdmond, type=temperature, property=feel"}
Number Temp_Feel_F "Temperature feel [%.2f °F]" {weather="locationId=homeEdmond, type=temperature, property=feel, unit=fahrenheit"}
Number Temp_Dewpoint "Dewpoint [%.2f °C]" {weather="locationId=homeEdmond, type=temperature, property=dewpoint"}
Number Temp_Dewpoint_F "Dewpoint [%.2f °F]" {weather="locationId=homeEdmond, type=temperature,
property=dewpoint, unit=fahrenheit"}
// min and max values only available in forecasts
Number Temp_Min "Temperature min [%.2f °C]" {weather="locationId=homeEdmond, type=temperature, property=min"}
Number Temp_Min_F "Temperature min [%.2f °F]" {weather="locationId=homeEdmond, type=temperature, property=min, unit=fahrenheit"}
Number Temp_Max "Temperature max [%.2f °C]" {weather="locationId=homeEdmond, type=temperature, property=max"}
Number Temp_Max_F "Temperature max [%.2f °F]" {weather="locationId=homeEdmond, type=temperature, property=max, unit=fahrenheit"}
String Temp_MinMax "Min/Max [%s °C]" {weather="locationId=homeEdmond, type=temperature, property=minMax"}
String Temp_MinMax_F "Min/Max [%s °F]" {weather="locationId=homeEdmond, type=temperature, property=minMax, unit=fahrenheit"}
// wind
Number Wind_Speed "Windspeed [%.2f km/h]" {weather="locationId=homeEdmond, type=wind, property=speed"}
Number Wind_Speed_Beaufort "Windspeed Beaufort [%d]" {weather="locationId=homeEdmond, type=wind, property=speed, unit=beaufort"}
Number Wind_Speed_Knots "Windspeed [%.2f kn]" {weather="locationId=homeEdmond, type=wind, property=speed, unit=knots"}
Number Wind_Speed_Mps "Windspeed [%.2f mps]" {weather="locationId=homeEdmond, type=wind, property=speed, unit=mps"}
Number Wind_Speed_Mph "Windspeed [%.2f mph]" {weather="locationId=homeEdmond, type=wind, property=speed, unit=mph"}
String Wind_Direction "Wind direction [%s]" {weather="locationId=homeEdmond, type=wind, property=direction"}
Number Wind_Degree "Wind degree [%.0f °]" {weather="locationId=homeEdmond, type=wind, property=degree"}
Number Wind_Gust "Wind gust [%.2f km/h]" {weather="locationId=homeEdmond, type=wind, property=gust"}
Number Wind_Gust_Beaufort "Wind gust Beaufort [%d]" {weather="locationId=homeEdmond, type=wind, property=gust, unit=beaufort"}
Number Wind_Gust_Knots "Wind gust [%.2f kn]" {weather="locationId=homeEdmond, type=wind, property=gust, unit=knots"}
Number Wind_Gust_Mps "Wind gust [%.2f mps]" {weather="locationId=homeEdmond, type=wind, property=gust, unit=mps"}
Number Wind_Gust_Mph "Wind gust [%.2f mph]" {weather="locationId=homeEdmond, type=wind, property=gust, unit=mph"}
Number Wind_Chill "Wind chill [%.2f °C]" {weather="locationId=homeEdmond, type=wind, property=chill"}
Number Wind_Chill_F "Wind chill [%.2f °F]" {weather="locationId=homeEdmond, type=wind, property=chill, unit=fahrenheit"}
// weather station (only Wunderground and Hamweather), needs version 1.7 or greater of the binding
String Station_Name "Station Name [%s]" {weather="locationId=homeEdmond, type=station, property=name"}
String Station_Id "Station Id [%s]" {weather="locationId=homeEdmond, type=station, property=id"}
Number Station_Latitude "Station Latitude [%.6f]" {weather="locationId=homeEdmond, type=station, property=latitude, scale=6"}
Number Station_Longitude "Station Longitude [%.6f]" {weather="locationId=homeEdmond, type=station, property=longitude, scale=6"}
Please let me know if you need any other information.
Not sure why I’m getting the html into the app instead of the parsed html.
For some reason, this is happening in Google Chrome, Firefox and the iOS app. My Internet Explorer is displaying it perfectly. Please shed some light.
Here is the screenshot from Chrome:
Here is the screenshot from Internet Explorer:
